gear drive ?
Discussion in 'The Hokey Ass Message Board' started by 50bomb, Mar 6, 2009.
  1. 50bomb
    50bomb
    from Lodi CA
    if i purchase a gear drive for my sbc 327 can i use the same timing chain cover?? probably a stupid question but you never know unless you ask!!
  2. 38Chevy454
    38Chevy454
    Most are designed to fit under stock cover.
    Now that I said what you wanted, here is my $.02: geardrives **** and I can;t stand them. They do not provide any significant benfit for performance ovfer a good chain set-up. They are obnoxious noise. They do not sound like a blower. OK, off my soapbox..........
  3. pecker head
    pecker head
    As said above , it will fit under stock cover ! And as for my preference they sound cool as hell ! I run one in my 265 !
  4. Mudslinger
    Mudslinger
    The noise gets old. It sounds like a power steering pump dieing.
  5. oface
    oface
    I think they sound *****in.
  6. R Pope
    R Pope
    Don't do it. I've made good money taking those things out of other people's engines when they fail. Many times the valves are bent when the cam stops turning.
    "If it works, don't fix it!"
  7. dbradley
    dbradley
    Gear drives have a single purpose. To drive the injector pump without wearing out a "chain". If its not equipped with mechanical injection, the louder the gear drive noise, the slower the car.
  8. zman
    zman
    from Garner, NC
    Puts a lot of vibration through the valvetrain. Not a good thing...
  9. 29nash
    29nash
    from colorado
  10. Zookeeper
    Zookeeper
    Sorry, I think they sound great (the quieter ones) and have never heard of anyone having problems with one. Yeah, I've read all the voodoo stuff about them causing valvetrain hysteresous, but seriously doubt it could be proven for a street car. Lots of Honda sportbikes had gear-driven cams, and they seemed to be fast and reliable. I say go for it, if nothing else it'll irritate the know-it-alls...
  11. bigchuckstud
    bigchuckstud
    The noise gets old in 2 weeks dont do it
  12. Hotrod1932
    Hotrod1932
    from Oregon
    Do it. Been running them for years..no problems. They sound *****en. Poor mans blower.
  13. I think the question was, "Will it fit under the stock cover?"
    Yes it will.
    Buy it if you like it.
  14. Old Rotor Flap
    Old Rotor Flap
    from Colorado
    I want one of those gear drives that you can switch on and off like Mel Gibson's blower drive in Road Warrior......
    Oh..... I guess the engine wouldn't run, would it....... let me think about that.
  15. Fishtail8
    Fishtail8
    It can be like driving around with the gf, wife or mother in law in your car all the time when they're in a bad mood, constantly badgering you and there's nothing you can do to make them quiet. It's your call either way.
  16. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    I put one in my girl's Fairlane with a 351W. I had to do some minor grinding on the inside of the cover, but that's just a Ford for ya. Nothing is easy on a $*&@#% Ford. On the SBC, you should be fine. I like the sound and after about a week, you forget it's making any noise at all unless you turn down the radio and roll down the windows. From outside the car, it sounds *****in'. She's been running it for about 4 years now and she's a lead foot. Never had a problem.
  17. redlinetoys
    redlinetoys
    from Midwest
    Yes, it will fit under the stock cover. The center pin is designed to be ground as necessary to fit on a sbc as well.
    I have a Cloyes cast aluminum cover on mine and the pin did require grinding. Just dry fit the cover with a gasket and grind only if necessary for a snug fit. With a tin cover, it will flex just enough to allow the pin to fit as is.
    MY two cents on a gear drive... I think it sounds *****in on the right motor. It sounds MECHANICAL like everything else on my drivetrain. With 4.88 gears, a whining Muncie Rockcrusher, Solid Lifters, lots of compression and cam, a fairly limited exhaust and a 7000 rpm redline, there is nothing sweeter than the combo of noise. A symphony if you will.
    On a stock small block with quiet or loud exhaust, well, lets just say it is kind of like the big picnic table wing on the back of a stock Honda.
    And, yes, in that case it does sound like a power steering pump going out...
    Do what makes you happy either way!
  18. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    That thing probably sounds like a B-17 taking off! :D
  19. -DMC-
    -DMC-
    from Ohio
    You may have to do some grinding though...And also, they have quiet ones and noisey, whine, ones...
  20. attastude
    attastude
    I read once that you can get the same results by rinning a wire from your coil to a a.m. radio with the speaker under your hood, at least you would be able to switch it off when you wanted. personally, I think gear drives are cool, but can understand it would be noisy on a long drive.
  21. 50bomb
    50bomb
    from Lodi CA
    thanks for the responses. glad to see i will not have to buy another item... and for the record i love that noise!!! it should complete my straight header to lake exhaust system sound in my 50 chevy. cops will probably love it too!!
    YOU ONLY LIVE ONCE!
  22. pecker head
    pecker head
    Gear drives & mini spools rule ! People are always saying dont do either ! I do both and enjoy both !
  23. MENACE
    MENACE
    from PHOENIX AZ
    My 2 cents i have a noisey pete jackson in my 302 and with the lakes headers you can only hear it in 2 and 3 rd gear and all the input i have from everybody is that it sounds good, i say do what you want
