Gear Drives...
Discussion in 'The Hokey Ass Message Board' started by SquigMachine, Sep 2, 2009.
  1. jamesgs4
    jamesgs4
    from denver
    hundreds of thousands of miles, just ask my old acura
  2. zman
    zman
    from Garner, NC
    They're about 70-100k, if you aren't having it changed you are asking for a big bill. And I'm wondering about the Jesel Belt drives for like a SBC. Not quite the same thing.
  3. Danog
    Danog
    I had a g/d in my old car and got tired of the noise, but I know I had no problems with it. The chain is a cheaper and quiet. My 2 cents.
  4. Hi!
    Hi!
    from SoCal
    Jesels recomended duty life is something like 60 hrs. The new white belts I dont know.
  5. jamesgs4
    jamesgs4
    from denver
    well it was a $300 car that wasnt worth working on, just flogging.
    there is even less harmonics transfered with a dry belt system. Belt technology today is pretty amazing, look it up.
  6. Ive been using a signle idler (quiet, made in Oz) gear drive on my souped up small block MoPars for years without a problem.
    Here's why:
    i. Its a known fact amonsgt MoPar small block guys that they are HARD on chains
    ii. Running decent valve spring pressures
    iii. Everytime I freshened up the short the chain would have too much play (like WAY
    too much) and it wasnt from line boring either.
    iv. never found metal shavings
    v. Gear drive provided easy cam timing changes
    vi. Hidden under stock cover
    vii. Has payed for itself, in fact still looks new !
    Valve train harmonics won't come into it for me at 6500 rpm. Maybe at 8K they would.
    Gigantor, Ill be running the same gear drive on my 330 Desoto Hemi.....when you're onto a good thing.......
    Rat
  7. Zookeeper
    Zookeeper
    I know we all have our views and all, but I like the "mechanical" sound of a racecar. I think straight-cut gears whether they're in a quickchange rear or a gear drive in the engine just sounds right. I don't think it's a poser's blower sound at all, it just sounds neat, and like any other car part, if you don't like it, don't use one.
  8. ELpolacko
    ELpolacko
    Running a Jesel belt on my TT-BBC. Expensive but oh-so-*****in! Very quiet and very, very accurate. The most stable my valve train/ignition has ever been. We spent plenty of time on the dyno with the scope hooked up recently, so if there was any fluctuation it was imperceptible to the machines.
    The quote I got from Jesel on the longevity is once a year I should change it because of the ramp rate of my cam. I'm good with that, I need to do an annual inspection on this monster anyway. For a daily driven street vehicle with moderate power output I could not comprehend doing anything else but a chain, single or double.
  9. elmitcheristo
    elmitcheristo
    I've had a gear drive in the BBF in my '29 for 12,000 miles. No metal in the pan and no problems with it so far. Call me a redneck, but I dig the noise.
    -Mitcheristo
  10. SquigMachine
    SquigMachine
    the noise has never been a problem for me(friends all have them, they sound nothing like a blower, M-22 or anything else that whines unless its another geardrive) I like how its half Chain half Gears.....you guys are going to screw my 20yr old mind up so bad.its all going to be a cost/power thing now(cheap and faster the better but no procomp haha)
  11. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Yep.....Smokey experimented all the time......and valvetrain dymanics was something he was really interested in.......he experimented big time on them (his engines). Everytime you'd buy a car from his shop.....it'd have all kindas od wierd stuff done to it....HeeHee.......He was a character.......
    He had a setup of timing gears, a crank gear, then a cam gear, with a idler gear in between......that was his favorite..........:cool:
  12. RichFox
    RichFox
    I have a gear drive in my car and it seems to be lasting very well and is nice and quiet. OH what is that? You say my Studebaker came stock with a nice quiet long lasting gear drive? Along with thousands and thousands of other cars. So why do you think after market gear drives are noisey except to attract attention.
  13. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    Timing gears don't last????????????????
    What about the 6's that all have gears??????......
    Evidently someone forget to tell ***mins, Cat, and all the heavy Equip. Guys that they don't last either.............
    HUM...........I Wonder>>>>>>>>>>>>>>>
