Technical Gear Oil Eaton Posi
Discussion in 'The Hokey Ass Message Board' started by 59Apachegail, Aug 4, 2022.
  1. 59Apachegail
    59Apachegail
    from New York
    I am in the process of building a 12 bolt rear with an Eaton Posi (clutch type). This one to be exact
    https://www.summitracing.com/parts/etn-19556-010
    Lucky for me I have been hanging on to it for a long time. Summit recommends a synthetic 80w-90 and an additive. Eaton says non-synthetic and no additive. The internet says 85w-90 from amsoil (synthetic) AND 80w-90 from Lucas. So what do you Eaton owners use for your posi diffs?
    …Yes this question was answered 10 years ago but back then Victoria Secret sent a catalog and the models were tall and thin : )
    SS327 and AVater like this.
  2. SEAAIRE354
    SEAAIRE354
    I have a similar Yukon unit and it wants non synthetic and friction modifier. I was researching the Eaton unit for a friend and I’ve read NO synthetic with clutch style units.
    Personally I would go with what the manufacturer recommends but I’ve always seen a modifier required. Just my 2 cents. I’m interested in seeing what others have to say.
    59Apachegail likes this.
  3. Tickety Boo
    Tickety Boo
    from Wisconsin
    Tryed synthetic in a 64 Chevelle 10 bolt and worked fine with the 225-75-15 street tires, but with 8" slicks it changed to a one wheel peel on the sticky drag strip.
    Changed back to the conventional oil with a posi additive and it's much better. "it might be time to rebuild it"
  4. AHotRod
    AHotRod
    Penn Grade GL-5 oil is what you want to use. We have tried many others over the years and have had issues with them all. We went exclusively to Penn Grade 6+ years ago at our Hot Rod Shop and it works flawless. Everything is in the oil, do not add anything else to it.
    PennGrade 1 Limited Slip GL-5 Gear Oil 77326
    You can get it at Summit Racing: PennGrade 77326 PennGrade 1 Limited Slip GL-5 Gear Oil | Summit Racing
  5. JWL115C
    JWL115C
    Whatever brand and weight you decide make sure it is GL-5.
  6. 59Apachegail
    59Apachegail
    from New York
    Thanks for the input all! I called up Eaton and they told me mobile 1 synthetic :confused:o_O
    I bought two bottles of the penngrade 1. If it hasn’t caused any issues for AHotRod in a Hot Rod shop for so long, it’s got be good.
    AHotRod likes this.
  7. 1971BB427
    1971BB427
    from Oregon
    I've always used straight 85w or 90w and always a friction modifier.
