Gear oil
Discussion in 'The Hokey Ass Message Board' started by Bill S, Aug 13, 2012.
  1. Bill S
    Bill S
    Is it O.K. to use GL 5 in the rear end of a Shoebox Ford?
  2. 29tudor
    29tudor
    I'd stick with 80w90
  3. Hnstray
    Hnstray
    from Quincy, IL
    Should be okay if it's the right "weight" (viscosity). The problem with GL5 is the additives attack the br*** syncro rings in transmissions........it does no harm to steel and iron parts. To my knowledge, there is no br*** in most rear ends and shoebox axle in particular.
    Ray
  4. Hummm....
    The car has gone at least 60 years without it, why use it now?!?!
    I say stick to what good 'ol Henry put in it in the first place.
  5. Hnstray
    Hnstray
    from Quincy, IL
    If you can get , agreed. The problem is the supercession of older formula oils with the newer blends has led to availability problems in some cases. GL3 went to GL4, GL4 is superceded by GL5 etc. etc.
    I found this out when trying to buy GL4 in the past year....checked all the local auto parts supply houses, farm stores, etc...no luck....ended up ordering online from Red Line Racing oil.
    Ray
  6. I hear ya... I stopped by an "Auto-Zone" while on the road this weekend and found out that they only stock multi weight motor oils... No straight 30 or 40!
  7. 57 HEAP
    57 HEAP
  8. fordor41
    fordor41
    except possibly in the bearings(spacers)
  9. ct1932ford
    ct1932ford
    I talked with a representative from Lucas Co. today. I was using a Lucas gear oil product but he said not to use the one I was using because of the GL5 soft metal issue. He recommended using a 50/50 mix of Lucas H D SAE 80-90 gear oil with the Lucas Synthetic Oil Stabilizer. The stabilizer will bring the viscosity up and protect all metals. The part #,s are 10043 for the oil and 10130 for the stabilizer. Note dealing with Lucas was just like the old days. I called the number on the bottle and the guy that answered the phone had all the information I needed. I did get an education.
  10. Texas Webb
    Texas Webb
    ^^^^ this is good info.I use lucas products in all my stuff.
  11. blue 49
    blue 49
    from Iowa
    I was looking at the Lucas Stabilizer, too, and saw it can be used up to 100% according to the wording on the bottle.
    Gary
  12. NOPSI
    NOPSI
    I've purchased GL-4 at NAPA.
    STA-LUBE GL-4 85/90
    Part# SL24239
  13. ct1932ford
    ct1932ford
    Again I was told by Lucas Tech to mix 50/50 stabilizer with the 80w-90w HD gear oil and it reduces the GL to acceptable levels for early differentials and gearboxes. Just did both my 32's.
