Gear ratio on a –56 Olds 88?
Discussion in 'The Hokey Ass Message Board' started by Orn, Sep 2, 2007.
  1. Orn
    Orn
    Did anybody know what gear ratio Olds use 1956 in an 88 with Rocket 324 and hydramatic?
    And is there any engine number decoding site on the net for these engines?
  2. Look on the rearend - there should be a little number stamped into the p***enger side of the pumpkin.
  3. yorgatron
    yorgatron
    most of them are 3.23 and if you post the engine number here i'll decode it for you.
  4. Orn
    Orn
    Thanks
    Here’s the engine number: V 1407498
    I hope I read them right; it was a little difficult to see.
    Btw, is the rear axle strong enough to deal with big block torque?
    I really appreciate your help.
  5. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    The olds rears were a**** the stoutest rears available from any manufacturer in the 50s...
  6. 41hemi
    41hemi
    The pumpkin will be stamped with one of four numbers to identify the gear ratio. Number will be on lower p***enger side of pumpkin on a little raised boss. #6 is a 3.64 ratio. #8 is a 3.42 ratio. #9 is a 3.23 ratio. # 0 is a 3.08 ratio. I got this info out of my 1956 Olds Shop Manual.
