Technical Gear ratio?
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Dec 7, 2025.
  1. fastcar1953
    fastcar1953
    Bought a 56 Chevy truck with I believe to be a Camaro rear end.
    These are the numbers on gear .
    I guess a 2.78 gear ratio.
    Toms Dogs likes this.
  2. lake_harley
    lake_harley
    2.78 gears.....ready to go land speed racing?;)
    If the engine it will continue pulling to 5000 RPM, with a 29 inch tall tire and a 1:1 top gear your truck will do 155 MPH:eek:
    Lynn
    winduptoy and saltflats like this.
  3. fastcar1953
    fastcar1953
    I will let you know lynn. :D
    I bought a 3.08 rear to put in it.
    I will rebuild it then swap them.
    I will be running 28 or 29 tire. No overdrive.
  4. justpassinthru
    justpassinthru
    2.78-1 to a 3.08-1 ratio change isn't worth the effort. Minimal change with a lot of work.
    No bang for your buck.
    Not knowing just what Camaro model and era that rear end is from,
    I would at least do 3.42-3.55 range with a 28"-29" tire. 3.73 range will limit your highway speed with max RPM.
    Bill
  5. fastcar1953
    fastcar1953
    I don't mind 3.08 or 2.78.
    I can drive it while I rebuild other rear.
    Thought I had 3.73 wanted to go higher.
    It will pull a 3.08 fine.
  6. Looks like 59 to my old eyes. Did you maybe count the teeth?
    Ben
  7. Joe H
    Joe H
    My 250 likes the 3.08 gear ratio with 28" tires, it will run all day long at 2400 rpm and 65 mph with no overdrive. The engine doesn't have enough power to pull an overdrive and 3.42 gears just used more fuel and raised to rpm above a comfortable level.
  8. Kerrynzl
    Kerrynzl
    Leave it alone and install a more modern wide ratio trans [Borg warner Super T10]
    A "Z" ratio ST10 with 3.42 first and 2.78 rear is exactly the same as a Muncie M20 first and 3.74 rear.
    But you get the highway cruising advantage of the 2.78 rear
  9. I bought an early Camaro rear and was told it was 3.08. Got it home, opened it up and ... UGH, 2.56. Installed in anyway, behind a TH350 and it worked fine. I believe I had a 305 SBC in that one. Never had a tach in it so don't know what the revs were. Drove fine and even pulled a small trailer at times.
    fastcar1953 likes this.
  10. flatout51
    flatout51
    2.78 gear with a 29" tire is 2,255 rpm at 70mph. 28" tire is 2,335 rpm. I have a shoebox with an 390 FE with a C6 and will be running a 2.79 with a 28.5" tire.
  11. Tickety Boo
    Tickety Boo
    from Wisconsin
    Looks like a 59 to me also. :confused: a 14 pinion would be a 4.2 gear ratio. :rolleyes:
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Call me crazy, but I built a RPU drag truck using 2.47 gears and 31" tall tires!
    Sure, it was slow, (ran 11s with a six) but it would hook in a mudslide and was as consistent as an hourgl***. Won a track championship amid several efforts to get it banned.
    Toms Dogs and winduptoy like this.
  13. Mr48chev
    Here are the rpm differences for 2.78, 3.08 and 3.55 gears with a 29 inch tall tire and 1 to 1 trans ratio. .
    This lets you see what rpm you should end up with at a specific speed with a certain rear end ratio, tire size and transmission gear ratio. Calculate RPM for Given Speed(MPH), Rear Gear Ratio, and Trans Gear Ratio
    Just for ****s and giggles and because I wanted to know I added 3.73 and 3.73 with overdrive. Screenshot (2174).png Screenshot (2172).png Screenshot (2173).png Screenshot (2175).png Screenshot (2176).png
  14. 1971BB427
    1971BB427
    from Oregon
    I don't think a 59 tooth ring gear would even fit the housing of one of those rearends?
  15. Toms Dogs
    Toms Dogs
    from NJ
