gear ratios , rmps & MPG
Discussion in 'The Hokey Ass Message Board' started by mullskull, Jan 25, 2014.
  1. gimpyshotrods
    gimpyshotrods
    The tail housing would have to come off. The 5th gear set in in there.
    Above shown is the output shaft, with the 5th gear set as the two gears that you can see. The fork to shift in and out of 5th is below the output shaft. The screwdriver is behind the drive gear.
    The teeth would have to be counted.
    Keep in mind, the ratio of teeth on these gears is NOT the actual 5th gear ratio. This gear set is subject to a reduction between gears farther forward in the system. The combination of those two gear ratios makes 5th.
  2. hoop98
    hoop98
    from Texas
    With a .59 you have a 2.95 gear set.
    Here are the available gears and teeth count.
  3. gimpyshotrods
    gimpyshotrods
    And there you go.
  4. mullskull
    mullskull
    you guys rule, thanks!!
  5. hoop98
    hoop98
    from Texas
    It's not what you know, it's what you can find out!!
  6. mullskull
    mullskull
    this is very very true!
    can the 5th gear set be changed from just removing the tails-haft, or does the rest of the gear box need to be opened up??
  7. hoop98
    hoop98
    from Texas
  8. gimpyshotrods
    gimpyshotrods
    "The only thing that you absolutely have to know, is the location of the library. " -Albert Einstein
  9. No. The speed limit is 55 going to the pits ;)
  10. hoop98
    hoop98
    from Texas
    Naw, 5500 to 3200 RPM drop, it doesn't have enough power to accelerate, so we slow down :)
  11. TagMan
    TagMan
    "The only thing that you absolutely have to know, is the location of the library." -Albert Einstein
    Today, he would have added "Google".<!-- / message --><!-- sig -->
