Technical Gear reduction starter is turning slowly
Discussion in 'The Hokey Ass Message Board' started by Hellfish, Jun 18, 2024.
  1. Hellfish
    Hellfish
    I have a freshly built engine that is outside of the car on a wooden dolly. I want to test a few things, and build up oil pressure before doing a break-in run, but the starter is not cooperating.
    The engine turns over easily by hand with the spark plugs in. The new gear reduction/ hi torque mini starter is correctly matched to the flywheel. Brand new, fully charged Optima with 910 cranking amps. Positive to the big terminal, negative to the starter body and bellhousing
    When I apply power, the engine turns slowly, pauses, turns a little more, pauses, turns a little more, but not anywhere near a full rotation or fast enough to start. The jumper cables get hot, like the ground is bad, but it's connected straight to the clean starter and a clean bell. New jumper cables, too, with clean contact points.
    I removed the starter and it works fine on the bench. The flange to flywheel depth is correct and the starter gear extends about the right amount and seems to be engaging with the flywheel fully.
    What should I check next? It seems like it's not getting enough juice, bad ground or the starter is weak.
  2. Happydaze
    Happydaze
    Use proper battery cables, not jumper cables.
    Chris
    SS327, flynbrian48, Mr48chev and 6 others like this.
  3. JohnLewis
    JohnLewis
    What gauge wire are you using?
  4. Mike VV
    Mike VV
    from SoCal
    Agree with the above...
    Use the proper sized cables. I'd bet you have inexpensive jumper cables. Maybe 4 or 3 gauge, both positive and negative.
    Both the starter needs, and the battery has more power than small cables can handle.
    The "hot" cable is a BIG clue !!
    "1", gauge if the battery is close (short cable) to the starter. "00", if it's 5ft (long cable) or further away.
    Mike
    jaracer and 2OLD2FAST like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Most any vehicle from the factory comes equipped with 4 gauge cables , many jumper cables are lucky to be 10 gauge .
  6. jaracer
    jaracer
    As others have said, if the cables are getting hot they are too small for the load. You can verify this with a voltmeter. Crank the engine and measure the battery voltage. It should be above 9.6 or you may have battery problems. Next, crank the engine again and measure the voltage at the starter positive terminal. It should be within 0.5 of the voltage measured in the first step. If the battery voltage measured at 10.5 volts while cranking, the cranking voltage at the starter positive terminal must be at least 10.0 volts. If the drop in voltage more than 0.5 volts, your cables are too small (gauge). Last step is to measure the voltage between the starter case and the battery negative post while cranking. It should never be above 0.1 volts. I expect you will see over 0.5 volts drop on the positive and over 0.1 volts drop on the negative.
  7. Hellfish
    Hellfish
    I hadn't thought about that! I'll give it a try
  8. Joe H
    Joe H
    Also, don't turn the motor over to build oil pressure, use a primer rod and drill motor. Turning the engine over just wipes off all the camshaft lube if it has any on it. If the camshaft was installed with a liquid type ***embly lube, it's already in the oil pan.
  9. Hellfish
    Hellfish
    It was the battery cables. Thanks!
    SS327, swade41, 2OLD2FAST and 2 others like this.
  10. Mr48chev
    I tried basically the same thing on an ot car yesterday. Car had a 7 year old stone dead battery in it that wouldn't take a charge and my hot battery and cheapie cables wouldn't get it to crank but would let me open the rear hatch with the electric switch and start my hunt for the well hidden battery.
    Desoto291Hemi likes this.
