Gear Selection Help
Discussion in 'The Hokey Ass Message Board' started by captinhowdy, Feb 9, 2014.
  1. captinhowdy
    captinhowdy
    What would you do with your rear end, if this were yours? Do you have a similar car....
    Ok here is the total package,
    Engine
    408 roller Windsor/stroked- maybe 480 HP/TQ to 520 HP/Torque.
    Holley Ultra 750 HP, using kick down cable
    CAM
    235/238 @ 50, 573/582 Lift - 112 lobe /mild
    Trans; A.O.D. from an 89 stang, BUT I built it up right and proper for the anticipated power range
    Stall @ 2200 converter (of course this can be changed)
    Drive shaft 3'' brand new.
    Wheels 27'' OD
    GW approx 3800 lbs.
    Suspesion; 2'' drop in front, stock height rear, 100% new.
    Blood type
    O Pos
    Sign Torus
    hanging itchy, low and slightly to the left
    I have an overdrive ******... I want have a nice cruiser but with m***ive get up, take off and go.... what rear end, posi, ls, 3.5, 4.11 ect. will help capitalize the top and low....
