Technical Gearbox ID
Discussion in 'Traditional Hot Rods' started by Stol, Nov 24, 2023.
  1. Stol
    Stol
    Hi ,
    Can anyone help me identify this gearbox ? The owner thinks it's a Model A or Model B, but to me it definitely doesn't look like a model A because the bellhousing is not separate?
    Also the handbrake looks to be mounted in a different position.
    Any help appreciated
    thanks
    Mark
  2. alchemy
    alchemy
    B had pedals mounted to the frame.
  3. seb fontana
    seb fontana
    from ct
    I seen a 26' or so Buick looked similar. Just saying.
    Stol likes this.
  4. Carter
    Carter
    Looks like a normal '28-'29 Ford model A transmission to me.
    manyolcars and Stol like this.
  5. alchemy
    alchemy
    Did only the big commercial A’s have a separate hogshead?
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Looks like model A with the e brake lever position, pedal mount and clutch inspection cover.
    Stol and Carter like this.
  7. Model A Gomez
    Model A Gomez
    Looks like a 28-early 29 Model A with the center mounted E-brake to me, kind of looks like a separation line between the trans and bellhousing in the second picture.
  8. Stol
    Stol
    thanks all for your help
