Gen 1 chevy sb dimensions
Discussion in 'Off Topic Hot Rods & Customs' started by TechieToo, Apr 19, 2025.
  1. TechieToo
    TechieToo
    I have learned a lot from this forum over the years and have now run into a problem that I have not been able to find an answer to. I have installed a TH350 into my 67 Chevy 2 Nova which required changing to a 168 tooth flexplate, unfortunately, the engine block only has straight across bolts for the starter. Does anyone know where to find the drawing dimensions for the third (diagonal) bolt hole based on the existing two holes for the starter in order to machine a drill fixture? Yes, I know I could use a mini starter with two sets of holes, I would prefer to use a stock starter.
  2. squirrel
    why would a TH350 require the large flywheel? That doesn't make sense. tell us about your torque converter?
  3. Casual 6
    Casual 6
    from Great NW
  4. DDDenny
    19Eddy30, 5window and Budget36 like this.
  5. TechieToo
    TechieToo
    Why a big 168 tooth flexplate? According to the ID codes on the th350, it was manufactured in 1978 and the bolt circle of the torque convertor bolts are on a 11 1/2 inch bolt circle, too big for the 153 tooth flexplate.
  6. I'd just get a smaller converter.
    squirrel likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    What Engine cid ? As in Oem
    Internally or externally balanced ,
    It sound like a Internally balanced
    Zero weight on flex plate .
    292-6 , 1978 more likely 305,,350 ,
    250-6 262 , 283,305,307,327,350,
    You can Bolt up diagonal out side bolt ,
    Square correct to Flex plate teeth ,
    Use transfer punch, then remover starter
    Drill & tap from Underneath ,
    Or change flex with Multi bolt patterns,
    Or Drill existing flex plate ,
    Bolt the 153 & 168 together, then transfer convertible holes , add a spacer on each bolt hole on converter ,
    You can use the OEM mini starter
    From 95- 2001 ish
    Or race Mini with 4 bolts
    ekimneirbo likes this.
