Gen 2 small block timing chain loose
Discussion in 'Off Topic Hot Rods & Customs' started by 327Eric, Jun 9, 2024.
  1. 327Eric
    327Eric
    I got a 95 LT1 for a good price, to put into the 65 C10 I'm building for my dad. I tore it down to check it out, and decided to put a new cloyes chain on, only to have it be as loose as the one I took off. The web says this is normal. Has anyone experienced this, or is have a set they used that doesn't install like it's got 100 k on it?
  2. guthriesmith
    guthriesmith
    Hmm…not sure I have ever had a new one seem loose that I can remember.
  3. SS327
    SS327
    They make timing sets with a shorter length chain for blocks that have the mains bored or honed.
    Balljoint, rc57 and onetrickpony like this.
  4. Deuces
    Deuces
    You might have bought the wrong gear and chain set..
  5. onetrickpony
    onetrickpony
    from Texas
    Like SS327 said, if the block has been line bored, you need a special timing set to compensate for the slightly shorter distance between the cam and crank.
    Deuces and Balljoint like this.
  6. ????? Really?
    Ben
    427 sleeper likes this.
  7. TA DAD
    TA DAD
    from NC
    Deuces and SS327 like this.
  8. Balljoint
    Balljoint
    I purchased a Pontiac 400 that had been rebuilt and line bored during the process. Me being a non trusting type of person, I tore it all down to check everything. I found a new chain on it and it was loose. I took a measurement across the diameters of the camshaft and crankshaft snouts and did the math to figure out that I needed a .004 reduced chain. It was snug getting the new chain on, in fact it had me worried it was going to induce bearing wear on start up, but it was fine. I think new chains tend to wear in pretty quick. You’ll need to know the factory dimension for crank to camshaft center to center on your engine to make this calculation.
  9. 327Eric
    327Eric
    Balljoint likes this.
