General Kinetics Cam I.D. Help
Discussion in 'The Hokey Ass Message Board' started by F-6Garagerat, Sep 26, 2012.
  1. F-6Garagerat
    F-6Garagerat
    Anyone out there have a old General Kinetics Cam catalog? I pulled this out of my 1957 283cu. in. It says,
    C1H254-S
    Which I know is:
    C=Chevy
    1=small block
    H=hydraulic
    254=advertised duration
    S= ??????
    I would like to know what the "S" stands for and what the lift of this might be. Its in good shape and I would like to run it. Im from the Detroit area where GK was located. Thanks for any help. Here's a few pics.
    Sent from my Droid powered Samsung Galaxy S
  2. falcongeorge
    falcongeorge
    from BC
    I'll take a look when i get home from work.
  3. Atwater Mike
    Atwater Mike
    Probably 'Solid'. (for mechanical lifters; engine being a '57, it would be probable.
    (time span)
  4. Deuces
    Deuces
    I used run those cams back in the day....
    $29.95.. That's pretty cheap.
    The most common was the 450/300 for a sbc...
  5. F-6Garagerat
    F-6Garagerat
    The "H" is for Hyrdaulic, the last letter denotes a change to the original grind, I just dont know what
  6. falcongeorge
    falcongeorge
    from BC
    I found a C1H254U single pattern 254@020, .333" lift at the valve, 254@020 .333[/EMAIL] 108 LSA. Description says "For late model smog engines. Some mileage gains". Smallest sbc cam in my 1974 GK catalog. Probably a Harold Brookshire lobe. I would take an educated guess at the duration @ 050 being in the area of 195-200. I would probably just put that one back on the shelf, if it were me. The S may indicate a LSA change.
  7. F-6Garagerat
    F-6Garagerat
    Ok. Thanks for the info. Not what I was hoping for, lol. Thanks for looking it up.
  8. vh1950
    vh1950
    To measure lift, take a pair of calipers and measure from the bottom of the lobe to the top of the lobe, then measure across the lobe. Now subtract the across the lobe number from the bottom to top number, then multiply that number times 1.5 (rocker arm ratio) that should be your lift @ the valve.
    kidcampbell71 likes this.
  9. 31Apickup
    31Apickup
    If you have a General Kinetics catalog can you look up the specs of another cam. I have one for a small block chevy which is number
    C1H290H
  10. BOBCRMAN
    BOBCRMAN
    from Holly
    The "S" just means the cam is a modified C1 H 254. The original grind being "A" then all revisions or variations were given an alphabetical model.
    Usually being the exhaust duration/centerline was moved. The cam centerline was modified. Lift on exh side was modified.
    Does not include "R" series which was their "white box" series of cams. Most of these profiles are still sold under various names. Very similar to "Energizer" series cams.
    I sold/used GK cams exclusively back in the day.
  11. falcongeorge
    falcongeorge
    from BC
    I have to work late tonight, If I can find the time when I get home, I'll take a look.
  12. falcongeorge
    falcongeorge
    from BC
    I have a C1H290-Z Dual pattern, 290/300, 465/490, 112 LSA guestimate at 050, maybe 225-230 on the intake side? A tad bigger than an L-79 cam.
  13. 31Apickup
    31Apickup
    Thanks for looking that up!
  14. maxblue
    maxblue
    I need help also with general kinetics cam, but my problem is that I have a new set valve springs p/n 94020 catalog number 4020 and would like infor on them. They are triple spring and I guess I got them along time ago when I had my drag car and I know i got them for a roller cam now I would like to sell them, but would like some infor to sell them.
    Thanks
    Ed in connecticut
  15. Easyspeed
    Easyspeed
    from USA
    Sorry to dig this back up, but I just pulled a general kinetics cam out of my sbc. It has C1M-310-B stamped in it. Can anyone help id it?
