general paint info and questions
Discussion in 'The Hokey Ass Message Board' started by gears-n-grease, Feb 7, 2008.
  1. So how about a thread on paint types, do's and dont's ect, so we have a general reference anytime we need it?
    I will post some of my questions and stuff that i may think is correct.
    1) Enamels can be used over lacquers
    2) Lacquers can not be used over enamels
    Primer's
    i really dont know much about them
    epoxy
    most may be used over steel, aluminum and body filler.
    Polyurethane Primer
    some are for use over bare metal, body filler, plastic, wood, aluminum, or fiberglass.
    acrylic urethane
    etching primer
    Modified Vinyl Etching Primer
    urethane
    most may be applied over old paint and body fillers making it ideal for block sanding. If using on bare metal or new metal, a self etching primer is recommended to be used before hand.
    acrylic lacquer
    If using over large areas of steel or aluminum or any bare metal, a self etching primer is recommended.
    Paint's
    nitrocellulose lacquer
    used mainly in the 50's and 60's?
    single stage, provides a deep finish if done properly and requires lots of buffing to achieve this.
    may not be available in all usa states, considered a "toxic" type paint to shoot?
    not sure what can be shot on top of it
    synthetic enamels
    single stage
    normal buffing to achieve optimum finish
    When Applying a non-metallic synthetic enamel color,shoot a mist coat. After allowing it to get tacky, follow up with a full wet coat. On a metallic color, the process should be reversed: One full wet coat, followed by a mist coat once the first coat has become tacky.
    Can be topcoated if it's totally dry and cured... But is suggested to take it down to metal to avoid alot of Mil's of paint.
    acrylic enamel
    single stage- however if you use hardener in the AE you can clear it with a urethane clear
    some acrylic enamels have excellent adhesion over virtually any original equipment (OEM) type finish with the proper preparation
    most acrylic enamels should be sprayed in medium wet coats allowing each coat to dry hand slick before the next is applied
    can be top coated with clear
    acrylic urethane enamel
    base coat / clear coat
    most types apply in two medium wet coats over properly prepared and primed surfaces. A third coat may be fogged as necessary to set metallic pattern evenly.Allow 5-15 minutes flash time between coats.
    Clears
    You can shoot base over Urethane clear.. or AE, etc....As long as the urethane is cured ....otherwise base will wrinkle it
    acrylic urethane
    Some May be used with single-stage urethane paint systems or other manufacturer’s basecoat and/or single-stage paint systems.
    Acrylic Polyurethane Clear
    Intercoat clear
    designed for use as a protective clear for artwork tape outs on basecoats
    requires topcoat clear
    Additives and concentrates
    flakes, pearls, concentrates ect
    i am leaving this wide open for input
    Questions
    what is synthetic enamel compatable with?
    what is acrylic enamel compatable with?
  2. 56Sedan
    56Sedan
    Enamel can be topcoated if it's totally dry and cured... however I prefer to take it down to metal.. I don't like alot of Mil's of paint.
    Acrylic enamel is a single stage however if you use hardener in the AE you can clear it with a urethane clear. I did a car once with Dupont Centari AE, then cleared it with PPG Concept Clear (2021) Came out really good, altho I don't like mixing brands of paint like that.
  3. SinisterCustom
    SinisterCustom
    As long as the urethane is cured ....otherwise base will wrinkle it....
    And intercoats are just that, intermediate base clears for "locking" down color bases for graphics and tape outs, dry very fast.....need to be cleared....
  4. 56Sedan
    56Sedan
    Good point! One I forgot to add...
  5. are there usually problems using 2 diffrent brands, i figured chemistry was chemistry?
  6. 56Sedan
    56Sedan
    There's generally no problem mixing 2 diff brand brands of paint,
    Some guys use PPG base with House of Kolor Clear, etc etc....
    It's just a matter or preference for me to stick with one brand, I don't need any added variables when it comes to painting a customer's car..
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    Yes, true. But when you spend $1K on materials do you really want to chance F'ing it up? The best way is to stay true with one brand and even the same line within a brand from start to finish. I generaly will use HOK primers esclusively. However sometimes I do topcoat with PPG Deltron. I haven't had any real problems, but I have had problems mixing other brands.
    Wait, we are agreeing. :)
  8. 8flat
    8flat
    Yeah, I always stick with one brand, unless it's on something I'm not too worried about, then I might get creative. Nothing worse than a paint failure...
