Technical Generator AND louver shop question
Discussion in 'Traditional Hot Rods' started by trucker1, Jul 19, 2016.
  1. trucker1
    trucker1
    I have a 1932 generator with 12 volt field coils. Can I use a three terminal regulator with it with negative ground? I need to run a generator mounted fan. If not has anyone adapted that 32 fan hub to a different Ford generator? Does anyone know of a good louver press sh op in Texas between Lubbock and McAllen or Lubbock and Albuquerque? Thanks, Glynn.
  2. electricalguy
    electricalguy
    Unfortunately No.....you have a 3 brush generator whose output is controlled by the moveable third brush. Only a cutout is required, and preferably a solid state(diode type), as the quality of contact style aftermarket replacements are typically poor.
  3. electricalguy
    electricalguy
    Oh...and polarity does not matter with this system, so no other changes need to be made(except reversing input and output on the ammeter.....
  4. trucker1
    trucker1
    Thanks EG I'm not sure if I'll try to move to the later gen maybe early 40's with 2 posts and use the fan hub on it. Can my field coils be moved to it? Glynn.
  5. fender lizard
    fender lizard
    from mcallen tx
    I have a large louver press with 3in domed traditional dies on it. Throat on my press is about 48 inches. Im located in Edinburg Tx 78539. Give me a call 956-219-6860 Danny.
  6. alchemy
    alchemy
    On my '32 I use a '32 fan, '40 front mount, '40-'48 housing, and 12v field coils, rear cover and armature from a '60 generator. I used to use a '38-ish fan-mount pulley with the ID bored to fit on the later 12v armature, but that subsequently cracked around the bore. I then found a pulley on a large Ford generator with the proper ID and the fan mount on the front. It fit perfectly, and I have no idea what it originally came off of. Maybe a fire truck or ambulance?
    Good luck in your search.
  7. trucker1
    trucker1
    Thanks Alchemy, I think I have most of the pieces, 60 something gen, a pair of 32 hubs and fans, a gen for crank mounted fan, and an 8BA type gen. I'll do some mixing and come up with a winner. My gen shop says I need to find a way to use a 12 volt armature to get the amps I need. Thanks again for your help. Glynn.
