Technical Generator cutout
Discussion in 'Traditional Hot Rods' started by Hyde_Auto_Body, Sep 30, 2013.
  1. Hyde_Auto_Body
    Hyde_Auto_Body
    We're converting a model A to 12 volt but this time we're using a 12V generator instead of going to an alternator. What is the best way to install a cutout on the generator to prevent overcharging?
  2. '54Caddy
    '54Caddy
    I used the stock Model A generator. I ordered a 12v negative ground cutout from these guys.
    http://www.funprojects.com/products/10505r.cfm
    Works great! Be sure to adjust the third brush on the generator to have the right amp output. The cutout comes with instructions on how to do it.
  3. I would use a voltage regulator designed for the generator that you are using (what are you going to use?). If you want it to look original (I do) put an original Model A cutout with wires on top of the generator and install the regulator in a hidden location. Trust me, you want to use a voltage regulator and not a cutout.
    Charlie Stephens
  4. Hyde_Auto_Body
    Hyde_Auto_Body
    We have some GM voltage regulators out of some early Chevy's that came equipped with generators. In this case we're not worried so much about original appearance. I wonder if one of these could be made to work?
  5. 40FordGuy
    40FordGuy
    Charlie Stevens is right; Go with a regulator.
    4TTRUK
  6. e1956v
    e1956v
    Alliance Vendor
    Ford generators are "B" circuit meaning the field is fed with 12 volts to make it charge. GM generators are "A " circuit the field is grounded to make it charge, so a GM regulator won't work you will need to use a Ford regulator. Hope this helps.
