Technical Generator ID? 6 or 12volt
Discussion in 'Traditional Hot Rods' started by Gergstuff, Oct 8, 2024.
  1. Gergstuff
    Gergstuff
    I have been chipping away at my long term hotrod project and am starting to wire it. It's set up for 12 volts but the generator I have came off another engine I had and it dawned on me that I don't know if it's 6 volts or 12 volts. Anyway to determine visually? It has a cover over it so i'd have to take it off the car and apart to see if it's marked anywhere. Hoping to avoid dismantling it.
    Any ideas?
    Thanks!
  2. BJR
    BJR
    Pull a light bulb off of the car and see if it's 12 or 6 volt. Otherwise take the cover off of it and it should be stamped on the case somewhere.
    jaracer likes this.
  3. Gergstuff
    Gergstuff
    No lights on car yet it's been built up from parts, I guess it's take it off and look for a stamping...
    Two steps forward and three steps back.
    Story of my life
  4. 302GMC
    302GMC
    from Idaho
    Ford ... look for stamped number on rear bearing plate, maybe ?
