Technical Generator or Alternator
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 17, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I understand the reasoning behind why one would chose one over the other but what are you using? HRP
    ladyhrp, 49ratfink and 3W JOHN like this.
  2. 3W JOHN
    3W JOHN
    I've used both and it depends on the car.
    I like the chevy alternator with the built in regulator and it's on my coupe.
  3. Alternator. One wire.
    Ben
  4. MercDeuceMan
    MercDeuceMan
    from Indiana
    Use both. Just converted one from Alternator back to generator. So 4 out of 9 vehicles are on generators.
    We won WWII using generators.
    Tater Bug, 3W JOHN, ladyhrp and 6 others like this.
  5. 392
    392
    Generator. To me without a hood it just looks right.
    Rich S., ladyhrp, rhtfo and 4 others like this.
  6. I know it doesn’t look right on a flathead, but the alternator works great, even with the lights on.
    And it gives me room for more carbs, should I decide to do that. 797A531F-3349-4D22-A955-07543F83320A.jpeg
    1947knuck, LOU WELLS, 3W JOHN and 5 others like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    IronFord, loner1, Bleach and 23 others like this.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Yes, yes it would. HRP
  9. hotrodA
    hotrodA
    Used a PowerGen on the flattie in the 32.
    loner1, 1947knuck, 3W JOHN and 4 others like this.
  10. Chappy444
    Chappy444
  11. goldmountain
    goldmountain
    I'm at a bit of a conflict within on this at the moment. My generator that I had chromed just went up in smoke. It cost more for the chrome than if I had just got a chrome 1 wire alternator. The repair bill for that generator will probably exceed the cost of an alternator too, and not put out the power of an alternator. Common sense and hot rods are mutually exclusive.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    bobbooth, joel, Tim and 8 others like this.
  12. 56don
    56don
    If I rewire everything and convert to 12 volts then I usually go with an alternator because I think its simpler and easier, but on my 1948 coupe I am keeping the generator, a flathead just doesn't look right with an alternator.
    3W JOHN, Rich S., ladyhrp and 2 others like this.
  13. Stogy
    Stogy
    Proudly behind the times with a 12V generator...goes with Bias Plys...;)
    3W JOHN, Ford52PU, ladyhrp and 6 others like this.
  14. Jay71
    Jay71
    Gen on the original 265. Never had a reason to swap it out.
  15. Truck64
    Truck64
    from Ioway
    Half the fun is just tweaking "civilians". Yes, alternators replaced generators for some very good reasons. But they still do the job. Someone looking at the engine:
    Them: "You know, you really need to get rid of that."
    Me: "Get rid of what?"
    Them: "That Generator."
    Me: "I do?! Why?"
    Them: "Because they aren't any good."
    Me: "What do you mean they aren't any good? It works fine."
    Them: "They aren't reliable"
    Me: "Well it's worked for 60 years, how reliable does it need to be?..." etc..
    Yes they do require brush changes and attention to detail, filing regulator points etc.
    3W JOHN, Rich S., 3340 and 8 others like this.
  16. 32Dan
    32Dan
    from Chino, CA
  17. Dan Hay
    Dan Hay
    56 Buick, 322 Nailhead - Generator
    38 Chevy, 327 SBC - Alternator
    3W JOHN, ladyhrp and HOTRODPRIMER like this.
  18. 302GMC
    302GMC
    from Idaho
    On 12 volt GM vehicles, the Delco generator from Buick & Cad with bearings on both ends, along with the D-R regulator that matches. With sealed bearings, I have yet to burn one down.
    3W JOHN, loudbang, ladyhrp and 2 others like this.
  19. hrm2k
    hrm2k
  20. Mr48chev
    It depends a lot on the car, the total engine compartment and then, where you plan to show it and or how far and how often you intend to drive it. If the car is a trailer Queen, never gets driven far enough from home to have to spend a night on the road headed to an event of you can't live with it being any other way a generator is fine but be prepared to start another Hamb " I'm stuck on the road with a burned out generator and can't find one or anyone to fix it". thread. With an alternator it's a stop at the first parts house or wrecking yard or Hambers shopshelf and go again and not be more than an hour or so late. One of mine gets the generator because it has to have one but it will never I over 300 miles from home under its own power. Is not for long trips. The truck gets an alternator because it will see a lot of long road trips over some real lonely roads. That alternator is so far down beside the engine you can't see it without leaning over the fender anyhow.
    Sent from my VS988 using The H.A.M.B. mobile app
  21. I use the GM alternators on most everything.
  22. rcavaliers
    rcavaliers
    from downey
    Depends on the car imho, if its in a hotrod I say generator IMG_20180817_132138_149.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    Hard Luck, loner1, desotot and 9 others like this.
  23. Ebbsspeed
    Ebbsspeed
    I have a 12 volt alternator on the '56 New Yorker, a 6 volt alternator on the '37 Buick, and a 12 volt alternator on the '52 John Deere. All Delco 10SI, and all wired the way they were designed to be.
    I also use a 120/240 volt alternator to run our house when the power goes out.
  24. I usually run the generator until 1) - the generator dies or 2)- I convert to 12 volts. If the car had an alternator in it when I bought it, it stays. I use the Down Under version of the generic GM 2 wire alternator, found on early 80's cars,
    cheap, (less than 20 bux at a swap meet),plenty of capacity (35 Amps), and the regulator can be changed without taking the alternator out of the car.
  25. dana barlow
    dana barlow
    from Miami Fla.
    I used a gen,in 1959 an up tell just a few years ago*. Frankly in 63 when my Dad got a Valint/slant 6 with a really neat little finned alum Alt. in it,WOW I thought how cool it'd be too polish up one of those an add to my 28 roadster hotrod ! So here is were I admitt I never found one I could get. I did go to a ALT. just a few years ago,for better starts an recharge. My son got me a chrome one wire ALT. like the one I got him,for his T-bucket. 002 (4).JPG
    desotot, texkbc, 1947knuck and 7 others like this.
  26. BamaMav
    BamaMav
    from Berry, AL
    I use the common internally regulated GM alternator on everything, Fords and GM's. Easy to find everywhere.
  27. Slopok
    Slopok
    If you are like me and only have lights, heater and keys, then a generator is fine.
    3blapcam, cvstl, 1stGrumpy and 6 others like this.
  28. mgtstumpy
    mgtstumpy
    GM alternator on my 35 (Down low and hidden) and a Powergen on the 46 Olds (Up high and visible for all to see), and above my X1 intake.:D
  29. I ran a generator on an old vette because it had a tack drive on it. On my HEMI, i wanted the look of a generator, but i realized it would block most of the cool valve cover so i hid a small alt down low out of sight.
    Tim, 3W JOHN, ladyhrp and 1 other person like this.
  30. 49ratfink
    49ratfink
    last generator I had was in 1976 to 1980 on my Chevy 261 six. 12 volts though. my 1965 Datsun may have had a generator as well... I don't remember.
    if I bought a running old car with a working generator I would probably leave it
    if I were doing a car from scratch the only thing I might have a generator on would be a flathead.. even then I'd probably have a generator looking alternator.
    EDIT: I'm glad other people go through all that bother, because all the correct old stuff on a old school car looks better.
