I have converted my generator to 12 volts in my 1950 F1 Ford and now need a pulley/fan that uses a 5/8" belt. Any ideas for replacement parts. Originals are hard to find. Thanks, John
Your truck should have 5/8" pulleys already, unless someone changed the water pumps, fan etc. You just need a fan from a 49-51 F1 truck or 49 only mercury that has the 5/8" pulley. You can get the pulley for the generator from the same. Hope this helps, Matt
Also add in '49 only Ford passenger as big belt. There are two pulley sizes amonst all of these, no idea which is from what application. (Here's a complete unit in the classifieds: http://www.jalopyjournal.com/forum/showthread.php?t=644966&highlight=generator a bit pricey since you need just pulley, but there are lots of generators out there, many with fat pulleys)
