Technical Generator pulley torque question, 1957 Ford Fairlane Custom
Discussion in 'Traditional Customs' started by johnny jackson, Aug 16, 2022.
  1. johnny jackson
    johnny jackson
    Guys,
    I am helping a friend work on a custom 1957 Ford Fairlane. Currently replacing the Generator. We have a new one and I have taken the pulley off of the old one and put in on the new one...question is how much to torque it? Anyone know?
    jimmy six and guthriesmith like this.
  2. Mr48chev
    They don't have to be all that tight, Probably 50 lbs if that.
  3. johnny jackson
    johnny jackson
    Mr48,
    Thanks for the response. I sorta figured that, it has a key to ensure the pully doesn't spin and a lock washer. I torqued it to 55 lb ft, that is in line with what you're suggesting.
  4. patsurf
    patsurf
    he's lying--should be newton meters,,,
  5. guthriesmith
    guthriesmith
    Sounds like you got the generator pulley figured out. Anyway, cool car. ***uming that is still a y-block in it with the three two’s?
  6. 302GMC
    302GMC
    from Idaho
    When did foot pounds of torque morph into pound feet ??
  7. jimmy six
    jimmy six
    Funny I’ve never found an alternator with a key.
  8. johnny jackson
    johnny jackson
    Ok, Jimmy six...the Generator does have a "key"...I just torqued it to 55 ft lbs because it seemed about right.....so in '57 Generator's had a "key"
  9. johnny jackson
    johnny jackson
    Guthries, the car has a Y-block...seems a bit tired.... I may axe some questions about that "tired-ness" soon....
    So you fellas got me on the FT LBS...verses LBS FT....funny. Newton meters is good....I know that dude Newton....
    Toms Dogs likes this.
  10. goldmountain
    goldmountain
    How do you hold onto the pulley to get a reading? I just zap it on with an impact.
    SS327 likes this.
  11. johnny jackson
    johnny jackson
    Goldmountain,
    I put a 2 bolts in 2 of the mount holes and then 2 punches on each side, jamming the pulley's vent area in two places, then torqued it. I first hit it with and impact, then worried I hadn't tightened it enough....
  12. jimmy six
    jimmy six
    My reference to a key was for alternators that just tighten the fan and pulley tight up to the main shaft and don't seem to worry about it. I've never torqued one eventho there is an Allen opening in the shaft. The nut is quit large and the threads are fine and I use a 3/8" drive battery impact.
  13. PHuscher
    PHuscher
    For those who like Ft/Lbs, wouldn't the metric equivalent be in Meter/Newtons?
