generator to alternator????
Discussion in 'The Hokey Ass Message Board' started by tko shea, Jun 21, 2005.
  1. tko shea
    tko shea
    from KOOLSVILLE
    I've got a 55 buick with a 264 and am wanting to change to a single wire alternator. How do I go about wiring it in so everthing still works.
  2. squirrel
    if you use a 1 wire alternator, then you won't have an idiot light working (***uming it has an idiot light, not a gage). If you want to make the idiot light work then use a normal 3 wire alternator.
    to wire up the 1 wire, all you do is connect the output terminal of the alternator to the BATT wire, and take out all the other stuff that you don't need any more.
    To wire up a 3 wire internal regulator GM alternator, you have to do the same to the BATT wire, but also connect a jumper wire from the output (screw) terminal to the 2 terminal and connect the wire from the idiot light to the 1 terminal.
  3. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    good info....wish we had a "favorites thread" section to our name...I would put this there!
  4. Mench
    Mench
    I agree,great info...send a note to Rocky...maybe he can start an "helpful hints" page..
    Mench
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Saved and posted years ago..
    Dont forget this important message...
    If you need to save more than one page.
    Every page must be saved like this. It does not automatically save multiple pages. PJ
    Here goes....
    OK, first, a quick introduction. I don't own a rod of any sort (or even an American car) and have been nothing but a lurker on here for a while. Until I have the money/space to actually build a rod (want all steel/flathead/rat style), I'll probably stay a lurker. I live down in Cedar Park, TX (just outside of Austin)
    On to the TECH.
    There have been some great articles posted. The question is, how to save them for future reference? You could print them out, but why not save them on your computer? You don't want to save them as html because that creates a bunch of folders and ****. Instead, if you are running Internet Explorer (sorry Mac/Netscape guys), you can save it as an MHT file. MHT files take all of the text and photographs and save it as a single file. Easy access for later!
    Here's how (it's pretty simple):
    1) Click on the page you want to save.
    2) When the page has loaded, click the File\Save As menu in IE. [​IMG]
    3) On the save as window, select the Web Archive, single file (*.mht) selection.
    4) Click on the Save ****on.
    The entire page (images and text) are now saved in a single file for later use.
    -Rob
  6. tko shea
    tko shea
    from KOOLSVILLE
    hey squirrel thanks alot for the help
