Generator with P/S pimp
Discussion in 'The Hokey Ass Message Board' started by Chuck M, Mar 9, 2013.
  1. Chuck M
    Chuck M
    What years did Chev have this type pump and was there only one type??Thank you.
  2. 40FordGuy
    40FordGuy
    The gen mounted P/S pump was used thru 1957, I believe, after which the seperate pump mount was used. As I recall, there was just one style that was used for generator mounting.
    4TTRUK
  3. Old Tin and New Tin
    Old Tin and New Tin
    1947 thru 1961. 1947 thru 1954 and then 1955 thru 1961 are the groups that will interchange, however there are some differences in the reservoir
    indentations and neck heights between some of the various years.
  4. 62rebel
    62rebel
    i have seen some pimps in Chevrolets but they seem to favor Cadillacs.
  5. Sphynx
    Sphynx
    from Central Fl
    And lots of gold accessories...:D
  6. BJR
    BJR
    We had a 58 Chev with a PS pump on the back of the generator back in 1965.
  7. Weasel
    Weasel
  8. 62rebel
    62rebel
    it was there; i HAD to do it.
  9. JEM
    JEM
    One typo and your life's ruined forever...
  10. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    We just like to have fun!
  11. It's like they say, change your own oil and no one calls you a mechanic, but give head just one time..........................:eek:
  12. 62rebel
    62rebel
    hell; you should see how real screwups get handled!
    it's not like you posted a Yugo on 22's and asked how to do a bowling ball paint job.
    and i've actually only seen one of those setups ONCE in my life. i think it was in a '59 or '60 Chevy (i wasn't much on Chevies then and wasn't really paying that much attention) and the car had every option you could think of, A/C, power steering and brakes, lots of chrome under the hood, and this was all loaded on top of a 4v 283.... too bad the car itself was a ****box so full of rust that touching it should have required a tet**** shot! that's how cars end up when they're out here on the coast too long.
  13. arkiehotrods
    arkiehotrods
  14. bobwop
    bobwop
    from Arley, AL
    funny how a place full of "experts" can come up with so many different answers to the same questions.
  15. kenymac
    kenymac
    I have a 1958 Chevy Impala Convt. With the power steering pump mounted on the the generator. They do use them on forklifts, But most rotate counter clockwise so beware if you try to use one. Also as said in another post they do have different reservoirs and some have different size pulley 55-61 12 volt earlier are 6 volt.
  16. aaggie
    aaggie
    The real problem with this setup was a slipping fanbelt caused the steering wheel to oscillate. There was another rare setup that had the mechanical tach driven off the generator shaft before GM put it on the distributor.
  17. "Expert?"
    An "Ex", is a has been, and a "Spert" is a drip under pressure!
    Doc.
  18. blowby
    blowby
    from Nicasio Ca
    And if you ran headers with that cheesey generator bracket it broke all the sooner.
