Can someone tell me how to remove the shift handle from the unit? I need to bend it to get it closer to the dash as all the "built-in" adjustment has been used. I see there is a roll pin to keep it in alignment, and a spring loaded detent in the bottom. Should it just pull out once the roll pin has been romoved, or is there something else holding it in?
Two little allen set screws at the base of the handle or "Shaft", just took mine off 10 minutes ago. EDIT: Just did another version and it had a roll pin as mentioned by others. Pulled the roll pin and the stick seems to be press fit to a lower shaft that is the detent. Not sure how it comes off of there
it depends if its a altra shifter or lo stick lo stick has 2 allens holding it on altra shifter is held on with a roll pin the roll pin is under a clip w****d around the base of the lever were it gose into the shift meckcinisim .the lever is spring loaded and held in with that roll pin
