Technical get the centre cap off this Octopus
Discussion in 'The Hokey Ass Message Board' started by johnrfray, Sep 1, 2019.
  1. Im doing the PerTronix Ignition thing on my 48 ford flathead 8 ,so I might as well do everything else, what is the best way to dismantle this octopus to change cap, and are these wires ok with the new unit
  2. Bandit Billy
    Bandit Billy
    [crickets chirping]
  3. Jack E/NJ
    Jack E/NJ
    from NJ
    You're supposed to send the thing to Jim Linder and let him handle it. That's his job. www.bubbasignition.com Jack E/NJ
  4. obviously I need to change my address in my profile , that way I wont get so many comedians on here ,thanks
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the main board. electronic ignition is not a subject for the traditional hot rod section
  6. alchemy
    alchemy
    Restore the distributor to original 1948 specs and use the 12 volt coil and condenser that Linder advises. Then change the cap, rotor, and the cap clips to 42 style and you will have a much easier to service cap and wires. No need for Pertronix.
    Moriarity likes this.
