Technical getting 1934 ford windsheild glass cut
Discussion in 'Traditional Hot Rods' started by jdm1932, Nov 9, 2023.
  1. jdm1932
    jdm1932
    from ohio
    My 1934 ford sedan project has about a 2 1/2 inch chop. I ordered a complete set of stock height gl*** kit. Can any reputable gl*** shop cut down my front and back gl***? I'm I going to need to make patterns for them to follow? I have no idea how to proceed.
  2. keith adams
    keith adams
    If it is safety gl*** (laminated) a good gl*** man should be able to cut it. Yes, it would be best to make a pattern.
  3. brokenspoke
    brokenspoke
    Yes they can, let them install in windshield frame
  4. BJR
    BJR
    If you have the stock height gl***, make a cardboard pattern from it. Cut the cardboard horizontally across the middle and overlap it by 2 1/2". Check the fit in your frame and in the window openings to make sure it is correct.
    dirt t likes this.
  5. twenty8
    twenty8
    Flat windshield should be no problem for a gl*** guy.
    This is a great tip.
  6. GordonC
    GordonC
    When I chopped my 47 ford coupe I just ordered all new flat safety gl*** cut to the templates I had made and provided. Was not that expensive really and had a local gl*** shop do it.
  7. jbon64
    jbon64
