Getting a cam reground?
Discussion in 'The Hokey Ass Message Board' started by gettingreasy, Dec 19, 2003.
  1. gettingreasy
    gettingreasy
    Does Schneider still regrind cams, are there other grinders still doing this? Do they harden the cams after ward, or not? Is this a decent idea if I have something that performance cams aren't around or just plain expensive.
    -Jesse
  2. Phil1934
    Phil1934
    I had one reground by Reed cams as they are in my town, Atlanta. It was only $40 or $50.
  3. ISKY! the only way to go
  4. gettingreasy
    gettingreasy
    They grind them to just about any spec? I want the cam in my Valient ground to the hyper pak specs(slant 6). I asume the cam must be in good shape with all the lobes there, anything else? Got any contact info for Isky and Reed?
    -Jesse
  5. Gr8ballsofir
    Gr8ballsofir
    Jesse to Action Speed & Machine in Mesa. He's pretty good...
  6. stealthcruiser
    stealthcruiser
    reed cams inc.
    770 474 6664
    170 andrew drive,stockbridge ga.
    don't have the zip.
  7. du$ty
    du$ty
    Schneider does reground them...i called about my 215 six.he had a n.o.s one he said he would grind to specs for 75 bucks...might give them a jingle.
  8. FEDER
    FEDER
    Remember. When buying a reground cam, especially when increased lift is involved. MAKE SURE to check your pushrod length.When they regrind cams the base circle is reduced to gain more lift.So check the pushrod length to make sue you dont have to much preload on your hyd lifters.If its a solid yer OK. Alot of times the grinder wont tell you so ya gotta buy new pushrods too.So for the price of a regrind and pushrods you could have bought a new one.---Feder
  9. gettingreasy
    gettingreasy
    Yaeh I'm gonna check push rod length(it is a solid tappet motor)with and adjustable H-D one. i don't want too much lift as the head is getting decked .100" so I'll stay around .450-.460 range(hyper pak is 455 I think). Great Ball's O' fire, you goota number or is he in the book? Thanks.
    -Jesse
  10. flying clutchman
    flying clutchman
    i have heard bad things about Scheider.
  11. Crosley
    Crosley
    from Aridzona
    I've used Schneider for a couple of reground cams in early chevy 6 cylinders.
    never had any trouble. fast turn around.
