Technical Getting a piston out of a block
Discussion in 'The Hokey Ass Message Board' started by TRoper, Jul 19, 2023.
Tags:
  1. TRoper
    TRoper
    Hi All,
    This is embarr***ing! I am dis***embling a Ford 429 that has been sitting outside for a couple of years. Have removed seven of the pistons and rods. The eight on was frozen in the block. I got the crankshaft to turn so I turned it so the piston was straight up. I removed the crankshaft so all that was left was the piston and rod. Turned the block over and since the piston would not come out through the top of the block I proceeded to drive the piston through the block toward where the crankshaft would have been. Now the problem, the piston will not clear and there is no way to get it lined up to go back into the cylinder. Any ideas on how to get the piston out?
    Thanks
    Deuces and chryslerfan55 like this.
  2. Texas Webb
    Texas Webb
    Is the piston trash or are you going all new( best bet)Remove all the rings it should go up. Use a torch cut it up!
  3. You mean it's clear of the bore at bottom, but you can't get it out of the crankshaft gallery?
    Deuces likes this.
  4. dana barlow
    dana barlow
    from Miami Fla.
    To bad your not closer to Miami Fla.,,,I have comeplet, 2 FE Ford big blocks 4 sale cheep $600 for the pair.{ both }not MEL but fit same Engine bay, If picked up here in Miami.
    You'll likely need to kill the piston completly to get it out.
    427 sleeper, Deuces and chryslerfan55 like this.
  5. squirrel
    What's preventing it going back in? The rings popped out of the grooves? If so, you can probably break the two top rings, and carefully pry the oil ring rails, then the spacer, out. Seems to me that once the rings are off, it should go back up just fine.
    And Dana, I don't know how FE blocks will help a 429, it's a different motor
  6. maybe he was thinking about a 428, iirc those are FE
    Deuces likes this.
  7. Marty Strode
    Marty Strode
    If you are not saving the piston, "drill baby drill" until it falls apart.
    bobss396, Deuces, big duece and 3 others like this.
  8. PackardV8
    PackardV8
    BFH
    jack vines
    56don, egads, Deuces and 1 other person like this.
  9. The last stuck one I did we melted the top of the piston out.
    Remove the rings you can reach and see if it can be pushed back in. If not ….
    I’d probably nibble that piston down with a blue wrench until it was small enough to fall out the bottom.
  10. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    If you have a plasma torch it cuts aluminum real easy without danger of hurting other parts. If you can cut most of the skirt out the remainder might tip over enough to fall out. Get a can of anti spatter spay at the welding supply store and thoroughly spray all surrounding surfaces. Hot sparks will not stick and cause problems later. Clean well with a wire brush when done.
    BJR, Deuces and anthony myrick like this.
  11. GordonC
    GordonC
    My flattie had stuck pistons. I drilled large holes in the top of the piston and caved it in on itself. Once I did that it released from the cylinder wall and was able to be removed. I had planned on boring it out anyway so that took care of any cylinder wall damage.
    Deuces likes this.
  12. Rickybop
    Rickybop
    Angle grinder/cut off wheel.
  13. swade41
    swade41
    from Buffalo,NY
  14. Get the rings out (if that's the problem) and turn the block upside-down so the piston is vertical. Fill the bottom of the piston with dry ice and see if it will shrink enough for you to push it out.
    Good luck!
    Deuces likes this.
  15. 427 sleeper
    427 sleeper
    Get a bigger hammer and keep beatin' on it, it'll go...
  16. Liquify...it can't get stuck if it'll pour! ;)
  17. Bandit Billy
    Bandit Billy
    Plasma wrench. Fast, effective, fun
    Deuces, 427 sleeper and 41 GMC K-18 like this.
  18. DDDenny
  19. SS327
    SS327
    Dynamite it out! 5 sticks should do it!
  20. seb fontana
    seb fontana
    from ct
    If you plasma or use a torch be carefull you can poke a hole in the cylinder in a heart beat.:rolleyes:
    Deuces and Johnny Gee like this.
  21. Dave G in Gansevoort
    from Upstate NY
    I prefer c4
  22. Bandit Billy
    Bandit Billy
    Good call, it is a ford after all.
    SS327, 427 sleeper and Budget36 like this.
  23. Deuces
    Deuces
    Plasteek...;)
    SS327 and 427 sleeper like this.
  24. warhorseracing
    warhorseracing
    from cameron wv
    Any of the above mentioned methods will work just be careful with the BFH and not damage anything but the piston.
    C4 is good but TOVEX is better.:eek:
    427 sleeper likes this.
  25. PackardV8
    PackardV8
    If he was careful, he wouldn't be in this situation. ;>)
    jack vines
    Beanscoot, swade41 and 427 sleeper like this.
  26. lostone
    lostone
    from kansas
    Now with all the words like c4, dynamite etc you know this post was immediately flagged by computers now prepare for the black helicopters and men in black suits !!
    :D
    Deuces, SS327, loudbang and 2 others like this.
  27. silent rick
    silent rick
    is it just a ridge keeping it from coming out the top? then remove or break rings and go back up with it.
    Deuces and williebill like this.
  28. Budget36
    Budget36
    Maybe the OP will come back in another year or so and update. Profile shows 16? Posts since 2010;)
    SS327, '28phonebooth and swade41 like this.
  29. warhorseracing
    warhorseracing
    from cameron wv
    They know how to find me. :pThey have been here before.:cool:
    427 sleeper and loudbang like this.
  30. 5window
    5window
    Maybe he has been busy. Or maybe everything was fine until now.
    SS327 likes this.
