Getting an old bird to fly again...
Discussion in 'The Hokey Ass Message Board' started by DYSFUNCTIONALJD, Jan 12, 2011.
  1. dabirdguy
    dabirdguy
    I would also look real hard ath the rubber lines....breake hoses, gas line, and vac*** hoses, not onnly gor cracks but for continued flexibility.
  2. espo35
    espo35
    from california
    T-Bird Sanctuary- talk to Bob (the owner). Anything you need, he has.
  3. DYSFUNCTIONALJD
    DYSFUNCTIONALJD
    Thanks for all the help guys. Yeah, it was originally sold in Ohio, so AC probably wasn't that big a deal when purchased. I can see wanting to add AC once i get it running and driving reliably.
  4. ynottayblock
    ynottayblock
    welcome to the club
    Doing alot of work on this one this winter. Lots of good advise from the guys posting here, if you do the work you'll enjoy driving these birds.
  5. DYSFUNCTIONALJD
    DYSFUNCTIONALJD
    Well, everything has been going fairly smoothly, carb rebuilt, engine turns over easily by hand, brakes didn't leak when bled. Only real problem is the fair amount of rust underneath in the rear. Front isn't bad, just the rear has it bad. Noticed it when i dropped the tank to clean it out. Tank is in good shape, just needed a good cleaning inside and out. Broke the bolts for the straps, so can't put the tank back in till new ones come in along with the rest of the parts to finish off the fuel system. This weekend I should be ready to fire the engine, not ready to drive, but hearing the engine roar will be nice.
    So any good advice for the rust? One friend said if it ends up not being totally rotted through to take a wire wheel and get as much off and then paint it with POR15. Is that the best solution (short of cutting it all out and totally rebuilding all the metal underneath)?
  6. I would get the car up on jackstands outside, rent or borrow a 3000# pressure washer and blast the underside, then paint with the coating of your choice.
  7. texasred
    texasred
    from Houston
    SOUTHWEST THUNDERBIRDS on hwy.71 east of LAGRANGE, he has had everything i needed for my 66 bird. Good "TEXAS" people good prices..DON HART RESTORTION products and services GAS TANK RENU WALLER TEXAS 800 321 4278
  8. low-n-slo54
    low-n-slo54
    Dang! Good looking car.
  9. Dakota Boy
    Dakota Boy
    from Racine, WI
    I did the "wire-wheel" thing to the entire underneath of my car this winter.
    Take off the tank, the rear axle, the pipes, the springs; everything from the firewall to the back bumper needs to come off the car. Then get a dust mask and a faceshield and go to town....
    Angle grinder with a 4" crimped wire cup. 4" Braided wire cup works for the really stubborn spots (You may run into some undercoating that is like concrete).
    Also get a few smaller attachments for a corded drill. Use those for the tight areas where the cup is too big. Any smaller pieces that can be removed could be cleaned on a bench-grinder wire wheel.
    Put some large sheets over your car's exterior or else you'll have a nice cake of dust all over EVERYTHING.
    It is NOT fun. Not fun at all. But the end result is the reward.
    I used Eastwood Rust Convertor and then non-rubberized undercoating on mine. A buddy of mine with an old Mercury is gonna use POR-15.
  10. Yutan Flash
    Yutan Flash
    from Gretna, NE
  11. bluestang67
    bluestang67
    Great birds from 55 to to 63 , Just dont let this one go . every thing you have is savable or rebuild able . Nice Bird @!!!!
  12. DYSFUNCTIONALJD
    DYSFUNCTIONALJD
    Just a quick update, got the engine running this last weekend. Will try and get a video up of it running soon. This coming weekend, its do the brakes and ******, then i should be able to start driving it around the block to check for any issues.
  13. willowbilly3
    willowbilly3
    from Sturgis
    Anything that sat 10 years, I would replace the brake system. Maybe not the hard parts but for sure the master cylinder, wheel cylinders and hoses.
  14. Ford52PU
    Ford52PU
    from PA
    how's the bird? Looking for one myself.
  15. FoMoCoPower
    FoMoCoPower
    you really need to learn how to resize pictures
