Projects Getting back to original paint.
Discussion in 'The Hokey Ass Message Board' started by Duellym, Mar 2, 2025.
  1. Duellym
    Duellym
    I have recently aquired this 41 Tudor. 20250223_115116.jpg Messenger_creation_E7AA596F-273A-4498-8393-01D30A13614A.jpeg
    The car has had a scuff and spray job done on it at some point in its life. Although whoever painted it forgot about the scuffing part of that job, I've used a blow gun and removed a bit of the blue paint off the factory black paint. I'm just wondering if there's a better way to get this car back to the factory black? I do for the most part plan on painting the car at some point but if I can get it back to black I'd really love to.
    Thanks in advance.
    34 GAZ and chryslerfan55 like this.
  2. BJR
    BJR
    Try a pressure washer.
  3. Duellym
    Duellym
    Definitely will once we get warm weather finially lol
    chryslerfan55 and guthriesmith like this.
  4. guthriesmith
    guthriesmith
    Yep, heated water through a pressure washer might do wonders to get most of it off if air blew off areas as you show. Seems like the best thing to try so as not to mess up the original paint.
    chryslerfan55 and Duellym like this.
  5. It’ll buff out. Hehe.
    Rand Man and Duellym like this.
  6. I was able to s****e some spray bomb black paint off of the steering column in my Nomad. Tedious, used a razor blade.
    Get what you can off with pressure washer and experiment.
  7. tb33anda3rd
    tb33anda3rd
    The blue paint may be falling off the spots on the car that still has black paint. If there were dents, rust or rot [probable] that was repaired there won't be any black to reveal. I would start s****ing, with a razor blade as suggested, in the areas most prone for possible repairs. sides of fenders , lower quarter panels , bottom of doors etc.. A little time researching may keep you from uncovering a calico cat, Jackson Pollack, Partridge family bus looking paint job
  8. Blue is a nice summer colour. ( and winter on a sunny day )
  9. Onemansjunk
    Onemansjunk
    from Modesto,CA
    The spray job has protected the metal from harmful surface rust or greater damage. Seems to be doing it at this very moment.
  10. Bugguts
    Bugguts
    I get that you want to remove the ugly blue, but from experience....42 years in
    Auto Collision repair and restoration, that is going to be a HUGE job, and then, as others said, there bound to be body damage under the blue. Every car I have ever stripped the paint on had hidden damage. Every one.
    Then..there’s all the areas that the blue will stick well and then you end up destroying the original paint trying to remove it. I’ve tried the razor blade s****e trick and it still gouges the under layers. Paint stripper will ruin all paint.
    I’m not saying don’t do it, but I guarantee that halfway through the process, you are going to question your decision and sanity.
    You mentioned eventually repainting it someday.
    I would be inclined to just drive it as is for now and laugh about the peeling blue until I could do it right.
  11. I’d cruise it just like it is
    let the wind take the paint off
    1pickup, AVater, jaracer and 3 others like this.
  12. RodStRace
    RodStRace
    Iron Trap did 'down to original' paint removal on a panel. I think he said it took 40 hours of hard work.
    www.youtube.com/watch?v=dNFkOYPuSc8
    What @Bugguts says is the truth. In modern times, it's like removing a wrap. You hope that it's pristine paint under, but that is never the case.
  13. Duellym
    Duellym
    I should've added that I am a bodyman by trade and I do know what I'm getting myself into in terms of labor or not knowing what's under it. There's a bunch of spots all around the car where there's rust bubbling under the paint that I want to take care of before they get bad anyway, but I'm pretty confident this car has never had any previous bodywork done to it so I am really curious to see if I can get the black paint to show back up and how well I could get it to look. I have just never tried doing anything like this before so I'm not even really sure where to start.
    Was thinking just using like 600 and an interface pad on a DA and spending like a whole month doing It and hoping i don't burn through the black, seeing what other people say they've done and weighing options really.
    Thanks
  14. Off the wall idea..... try oven cleaner on a small incon****uous spot. The other thought I had is try a steamer (the type used on d****s etc.)
    Duellym likes this.
  15. RDR
    RDR
    Pretty sure that the... Diamond Gloss... Earl Schieb Blue wouldn't be affected...
    by any oven cleaner...
    BUT... if the black lacquer is original...IT will be
    good luck
    Duellym likes this.
  16. Duellym
    Duellym
    That's what worries me with doing any chemical stripper on the car, I know any of that will take the lacquer right off no problem but is gonna struggle with whatever this blue paint is, I think it was painted in the early 2000s so my guess is it's acrylic single stage.
  17. Rickybop
    Rickybop
    You might enjoy this video.
    Duellym and RDR like this.
