getting courage to cut firewall.
Discussion in 'The Hokey Ass Message Board' started by Smilin Jack, May 17, 2013.
  1. Smilin Jack
    Smilin Jack
    Encourage me fellers.
  2. Tnomoldw
    Tnomoldw
    :)Looks like you can turn it around . :cool:If you have to trim more , it 's only sheet metal,,,,:D:eek:
  3. Smilin Jack
    Smilin Jack
    I don't really care for the look when turned around. Might be easiest though.
  4. jonathan
    jonathan
    from Phoenix,AZ
    Maybe just leave it out and make a flat firewall?
  5. rustednutz
    rustednutz
    from tulsa, ok
    I hope you are going to do a lot of triangulation on your frame crossmembers or you are going to twist that frame like a pretzel with a BBC. Other than that what's the hold up on cutting?
  6. 325w
    325w
    Make yourself happy. Do it the way you want it. Look at zip water pump for some rad. Fan clearance.
  7. Lowrders
    Lowrders
    from DUBUQUE IA
    Don't think too much about it. Stop looking at it like its an un fixable mess if you destroy it. Its only metal. Its not like its a deusenburg or something, its a model a. Quit being a *****. Sawzall the **** out of it. Torch it! Run it over with a monster truck carefully. Or take your time, cut it gently while listening to cl***ical music. duck tape it. bondo it. staple it. rivet it. self tapper it. or weld it. JUST DO IT!!!!!!!!!!
    How's that for a little A.D.D motivation on a Friday?!
  8. Gotgas
    Gotgas
    from DFW USA
    You'll have a lot more room without one... ;) :D
  9. Smilin Jack
    Smilin Jack
    Lowrders, that's the motivation I needed. LOL
  10. Atwater Mike
    Atwater Mike
    If a BBC has been proven to be the 'motivation' you need, the firewall can be compromised...
  11. Smilin Jack
    Smilin Jack
    Yeah,
    it's not like the firewall ain't full of holes. I'm keeping the body as stock as Henry made it as much as possible. The firewall can be expendable if I mess it up.
  12. ChefMike
    ChefMike
    Sometimes you just need to do it! and by that I mean jump right in and go for it! in the end I'm sure it will turn out find!
  13. 1971BB427
    1971BB427
    from Oregon
    I'd agree with reversing it, but if you're not into that look, then I'd cut it in a second. Of course I've never hesitated in cutting a firewall on anything common. If it was a concern to save the firewall, then I'd be using a different engine to save it.
  14. Smilin Jack
    Smilin Jack
    I think I'm trying to decide if I want to go the wheel barrow bed route or cut out what I need to cut and recess just that.
  15. 327Eric
    327Eric
    If you want to retain originality, hang the original firewall on the wall, and pick up another one to cut up. If you decide to go another direction in the future, you will be able to go back.
  16. c_lay54
    c_lay54
    Just put a FORD in it and use the chev as a door stop. :) What ever you make it how YOU want it not how others tell you it should be.
  17. F-6Garagerat
    F-6Garagerat
    image.jpg Just cut it. Reversed doesn't look right to me. I made a template with poster board for the insert. Didnt lose toeboard either.
  18. -impalamike-
    -impalamike-
    check out my build, there are lots of pics. We did 3 1/2 recess. It's just metal, if you screw it up it can be fixed
  19. el Scotto
    el Scotto
    from Tracy, CA
    You can get a really nice Model A firewall around here for $50, hack it up!!
  20. swade41
    swade41
    from Buffalo,NY
    With that air cleaner, who is going to be looking at your reversed firewall anyway ???
  21. Smilin Jack
    Smilin Jack
    Hey Swade, how's it going? I'm looking at doing a flat firewall welded to the back of the original firewall flange then cutting the old firewall off. That will give me enough clearance for everything except maybe a small recess for the distributor. Gonna do a search for flat firewalls for some ideas. Thanks all.
  22. HOTRODPRIMER
    HOTRODPRIMER
  23. threewindaguy
    threewindaguy
    Make sure you allow room to get your distributor out if need be....
  24. -impalamike-
    -impalamike-
    heres a couple of pics of mine. I am running a Pertronix flamethrower 2 distributor. It's a close fit. I have to pop the cap off to get the distributor in. It's a 3 1/2 recess
  25. HOTRODPRIMER
    HOTRODPRIMER
    Nice job and it looks good also. HRP
  26. Smilin Jack
    Smilin Jack
    Impala Mike, that's a good looking job you did. I think a flat firewall is my easiest answer. I did a search and found exactly what I had in mind and it looks great.
  27. -impalamike-
    -impalamike-
    Cool man, good luck. Looking forward to seeing what you come up with
  28. swade41
    swade41
    from Buffalo,NY
    Make sure and brace it somehow, without beads rolled in it may flex.
  29. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Just cut the ****er up. :)
  30. NATESBPD
    NATESBPD
    Do it! You wont be sorry if its done the way you want it!
