Technical Getting into my trunk
Discussion in 'The Hokey Ass Message Board' started by John Wayne Customs, May 7, 2018.
  1. John Wayne Customs
    John Wayne Customs
    Can anyone give me an idea on how to get in my trunk. I have a 1951 buick and the lock cylinder is gone and the trunk is closed. I would have to cut some braces out to get to it from the inside and even then I couldn’t fit. But my daughter could. But....I don’t know how to open it from the inside either. Any help would be greatly appreciated!
  2. s55mercury66
    s55mercury66
    from SW Wyoming
    If there is an open hole where the lock cylinder was, shine a flashlight in there and see what you can see. You may be able to stick a long screwdriver in there and turn it to open it.
  3. AldeanFan
    AldeanFan
    I’ve had luck reaching in through the back seat and unbolting the trunk latch.
    Use a bunch of extensions and tape them together so they don’t come apart.
  4. lothiandon1940
    lothiandon1940
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    If only the lock cylinder has been removed, and the rest of the lock is still on the outside, you may be able to turn what is left with a screwdriver also.
  6. Special Ed
    Special Ed
    We had one come into our shop like that, and fiddled with it for about fifteen minutes with a standard screwdriver until it finally "popped" .... just be patient, and keep jiggling it.
    lothiandon1940 likes this.
  7. Deuces
    Deuces
    I ummmm... No comment... :rolleyes:
    RMR&C and 5window like this.
  8. rusty1
    rusty1
    ...use the screwdriver,sometimes it helps to push down on the trunklid a bit...
  9. When you say gone do you mean missing ? Or gone and in NFG?
    If it’s missing sometimes you can go through the hole with a screw driver or a pic and hit the lever and open the trunk that way
    If the Cylinder is still there you could try picking it
    Or google image your trunk latch
    You might be able to get to in by drilling a small hole in the trunk floor or just under the key cyl and tripping the mechanism
  10. earlymopar
    earlymopar
    I just don't like the ***le of this thread......
    lothiandon1940 and Trebor0012 like this.
  11. 302GMC
    302GMC
    from Idaho
    Give the little gal a 1/4'' ratchet & deep 3/8'' & 7/16'' sockets. Unbolt the "U" shaped latch catch from the floor. She's gonna need a flashlight ...
  12. 41rodderz
    41rodderz
    from Oregon
    :p:D:oops:
  13. Mr48chev
    If the lock cylinder is missing It should be pretty easy to open it with a screwdriver and that is probably the cylinder is missing in the first place. I used to know a guy who liked to punch the lock cylinders in cars in wrecking yards to see what he could find in the trunks until a yard owner caught him in the act one day and bruised him up a bit. Back in the days when if you got your *** whipped for screwing up someone's stuff an costing him money you didn't go running to the cops over it.
    First thing I'd do is look in the lock cylinder hole and see if there is the little rectangular hole in the back or a hole that the end of the lock cylinder went into to turn the latch.
    Otherwise you can probably do the long extension thing. I've got a long SnapOn speed handle an a long extension that have been use to open more than one trunk that way.
    lothiandon1940 and Hnstray like this.
  14. Hnstray
    Hnstray
    from Quincy, IL
    Yep......that was often enough of a ‘lesson’ to change one’s behavior for the better...instead of today’s approach of giving the a$$hole ‘victim’ status....
    Petejoe and lothiandon1940 like this.
  15. Budget36
    Budget36
    So true...back in the 70's before pick and pulls...you used to be able to go through the yard, take your tools and find what you wanted. But them guys who ran the yard were no dummies...they knew when you went in...and when you should be out.
    After a bit...some other yard guy would come checking on you, most likely to make sure you weren't ripping out the dash of that pickup for a 3 dollar part.
    ****, I was so scared I'd show them the screws I was keeping...lol...never got charged for them, but always got a nod.
  16. Mr48chev
    That particular yard owner was pretty pissed that over a year or so the guy had screwed up the holes around the truck locks on probably a hundred trunks in that yard alone. Not only got is **** kicked but was banned from the yard for life. I think I actually bought one of those trunks he had punched and had to fix the hole around the lock so it would hold a lock.
  17. southcross2631
    southcross2631
    I have a screwdriver bit that I put on a long extension . Take the back seat out and take a look.
    You could always cut the trunk floor out and the rest is easy.
  18. tb33anda3rd
    tb33anda3rd
    on my 53 buick after removing the back seat and getting the trunk card board out of the way i was able to reach in and use a long pry bar to slide the lock cylinder clip off. p.i.t.a.! then pulled the cylinder out from the out side and used a screw driver to open the latch.
    Hnstray and lothiandon1940 like this.
  19. tb33anda3rd
    tb33anda3rd
    if you look close, you can see the clip, slid back on the lock cylinder, i sitting on the trunk floor. IMG_1282.JPG IMG_1292.JPG
    the clip is key hole shaped. it needs to be slid so the lock can slip through the bigger hole.
  20. John Wayne Customs
    John Wayne Customs
    Yes the lock cylinder is missing, when I look in to the hole I see a little rod/lever protruding I tried to grab it with some needle nose but couldn’t get hold of it. I see two bolts on the inside of the latch. So if I can take those bolts out will that release the trunk?
