Projects Getting paint off of chrome
Discussion in 'The Hokey Ass Message Board' started by micahmelanson, Jul 21, 2009.
  1. micahmelanson
    micahmelanson
    from Vinton, LA
    Does anyone have any remedies for getting paint off of chrome? My three year old decided he wanted to paint Daddy's car and got the bumper.
  2. 19Fordy
    19Fordy
    Lacquer thinner, paint reducer, gasolene, mineral spirits.
  3. Long Roof Larry
    Long Roof Larry
    Triple O steel wool.
  4. pigpen
    pigpen
    from TX USA
    ...paint remover gel, acetone, anything that will cut paint. Don't use acids or abrasives, although SOS will work but may leave a haze. SOS does work well on old chrome that has some rust comming through. Gets the rust off without too much damage. pigpen
  5. skullhat
    skullhat
    as said, laquer thinner will wipe spray can paint right off. if its any trouble at all, soak a rag then lay it on the paint for awhile.
    i spike my thinner with m.e.k.,as the new stuff is weak, but you'll be surprised how easy it is to wipe off
    skull
  6. tommy
    tommy
    Paint remover. I wouldn't use anything abrasive. Gum cutter will probably do it but a small can of paint remover should do it. Chemicals won't hurt the chrome but steel wool can. JMO
  7. BobG
    BobG
    Spray can paint stripper is easy and won't hurt the chrome after it removes most or all of the paint, finish the clean up with lacquer thinner on a rag then use chrome polish.
    If the chrome is nice I'd discourage using steel wool as even the finest steel wool can scratch chrome.
  8. lownslow
    lownslow
    and NEVER use steel wool . even the finest will ruin the chrome .
  9. Larry T
    Larry T
    Spraycan carb cleaner (Berryman B-12), spray a little on a rag and wipe the paint off.
    Larry T
  10. falfas55
    falfas55
    0000 Steel wool,lacquer thinner,then Mothers Chrome and Gl*** Cleaner. Do not use an SOS pad,it'll ****ch the chrome. FALFA
  11. Retro Jim
    Retro Jim
    Did you consider why someone painted the chrome in the first place ?
    Maybe they painted it because the chrome was bad !
  12. lownslow
    lownslow
    they who ? his kid did it .
  13. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    Reading the post helps. :D Just messin' with ya.
    As said, just about anything works for that. Hell, I've used Brake-Kleen before and it did just fine. Here's an old pinstriper's trick. Oven cleaner. It'll take off pinstriping from a paint job without hurting the paint underneath (about 90% of the time). Good luck.
  14. autobodyed
    autobodyed
    from shelton ct
    As said, just about anything works for that. Hell, I've used Brake-Kleen before and it did just fine. Here's an old pinstriper's trick. Oven cleaner. It'll take off pinstriping from a paint job without hurting the paint underneath (about 90% of the time). Good luck.[/QUOTE]
    he's absolutley right, first time i hears this i said, yeah right! but i was amazed at how nice it works. just goes to show, if you want to, you can learn something new everyday.
  15. 52style
    52style
    brake fliud just make sure not to get it on the actual paint on the car !!!!
    put it on a rag wipe it on the paint give it an hour or to and come back to ythe paint peeling off
    no steel wool needed even 0000 will dull the chrome
  16. Squablow
    Squablow
    I'd just use paint stripper, but for cryin' out loud, quit suggesting steel wool people! That's the worst thing you can do. I don't care how "fine" it is, you're scratching the surface, it's an abrasive.
    Even if it's a rusty old bumper, you're much better off to use some buffing compound and a rag over steel wool.
  17. Gene@Gearworksmfg
    Gene@Gearworksmfg
    Oven Cleaner is great for removing a thin layer of paint. I used to use it on aluminum sportbike frames to remove the clear anodized layer before I would polish them. The great thing is that it's not too harsh. I think the best brand was "easy off"
    Good luck
  18. loburban
    loburban
    Brake fluid I just traded for a car with chrome reverses that had been painted red and the guy I got it from had stripped them with brake fluid and it did not hurt the chrome.
  19. Dang, what WAS her name?.......
  20. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Easy off oven cleaner will take spray paint right out.
    Brake fluid is well known for eating the piss out of paint.
    WD40 might even do it. Seem to remember hearing something like that.
    The Castrol Super clean degreaser (purple) will do it too.
  21. skullhat
    skullhat
    funny, by the time you read all these posts, the paint will probably have just fallen off, as it wont stick to chrome anyway. lol
    skull
  22. 325w
    325w
    Mr. Skullhat. Read the MSD on MEK. That is nothing to be using in general use. MEK is some bad stuff. WE learned some hard lessons at Obama Motors years ago. IMHO
  23. skullhat
    skullhat
    as with most haz chemicals, they do have to be handled safely.
    for years you could just get it at the hardware store , lol.compared to some of the stuff we see here every day, mek is actually quite mild :)
    skull
  24. micahmelanson
    micahmelanson
    from Vinton, LA
    Thanks for all the help
  25. MrHavard
    MrHavard
    I just stripped paint of the grill for my '53 belair using Aircraft Stripper. It worked really well but now I see that the chrome that was underneath looks more like copper. Is there anything I can do with that?
  26. Sirweesarunch
    Sirweesarunch
    If its water based paint use Xylol .. you can get it at any home paint store .. solvent based paint needs a lighter solvent like laq. thinner .. Dont use the rag sopping with thinner . make the rag into a ball and just pad and move in straight line .. You melt the paint and in the next swipe remove whats loose till its all gone ..
  27. 19Fordy
    19Fordy
    You will have to get it chrome plated again. Copper - Nickel - then Chrome.
  28. MrHavard
    MrHavard
    Well damn, I might as well just re-paint it. I don't have the cash for re-chroming. After stripping it I found a couple spots of filler also.
  29. DrJ
    DrJ
    NO!!!!! NO!!!!!! NO!!!!!
    ANY abrasive destroys chrome.
    Chrome is only microns thin, and basically clear. What "Shiny" you are looking at is the polished Nickel under it.
    If you use ANY metal wool, all you will have left is the Nickel under neath it and it WILL tarnish, soon.
