Hot Rods Getting the lines right....
Discussion in 'The Hokey Ass Message Board' started by hfh, Apr 27, 2018.
  1. hfh
    hfh
    from Western MA
    IMG_1881.JPG The next thing for me is to find a nice way to hide the lower radiator hoses and the part of the radiator that extends below the grille.
    Corsa, Okie Pete and Stogy like this.
  2. pitman
    pitman
    Depending on yr. prefered matl., I'd tape some 3/8" foam onto the hoses & tank for 'standoff' then bend up and weld a tin splash shield, or lay up a gl*** one. (***uming you can't locate a stock one to modify)
  3. LM14
    LM14
    from Iowa
    Lines came out great.
    For the "chin" piece I would just create a metal piece that extends the lower lines of the grille shell to the top edge of the frame rail. That defines the top and back edge. Then a front/lower edge like a '32 ford filler piece had. Could make it flat, angular or my favorite, curved from the front edge to the bottom of the grille shell to compliment the shape of the shell.
    SPark
  4. 41rodderz
    41rodderz
    from Oregon
    I have to agree. Spot on:cool:
  5. scrappybunch
    scrappybunch
    from nj
    Looks really good! Side note: like the pivot bike too.
  6. lippy
    lippy
    from Ks
    Looks great! But I am a curious cat. Wonder what it would look like with a chopped flat windshield layed back. ? Lippy
  7. Tim
    Tim
    from KCMO
    I’d think something similar to the stock A front splash pan would cover that all nicely
  8. hfh
    hfh
    from Western MA
    IMG_1871.JPG IMG_1872.JPG Thank you all for your suggestions. Since the shapes in this grille remind me of the many unique grilles on vintage race cars, I looked at pictures of these old cars as a guide on how to finish the lower area. Some old race cars had a panel below the grille and between the frame rails. I started making one of these out of aluminum that would extend out and around the spreader bar. Before I had completed it I tried it and it looked too overpowering for the grille. So I'm going to try reducing the size and shape of this panel.
    Tman, brEad, Texas57 and 3 others like this.
  9. tb33anda3rd
    tb33anda3rd
    it probably won't look too overpowering once it is painted black. maybe try making it in cardboard first.
    hfh likes this.
  10. hfh
    hfh
    from Western MA
    Thanks. You are absolutely right. I am doing this partly to learn something about working sheet metal. I'll finish the panel and paint it and then decide whether or not I like it.
  11. 1-SHOT
    1-SHOT
    from Denton
    Just spray bomb it black and see how it looks, then you can wipe it off with thinner to finish it. Frank
  12. Okie Pete
    Okie Pete
    The chin needs to the old time racer look . Looks great .
  13. something like the factory cover ?
    The challenge would be getting the side to both , blend in and cover the hoses.
    That is an interesting bottom tank configuration, pretty cool!
    Stogy likes this.
  14. hfh
    hfh
    from Western MA
    So many great ideas! Thank you. I had not thought to look at what went below the grille on the original car. Maybe less is more in this spot.
  15. Excellent reasoning and excellent execution on the line of sight and the panel below the grille shell. Me like!
  16. Stogy
    Stogy
    I'm in a rush but here's a little attempt at something related
    hfh, Peanut 1959 and tb33anda3rd like this.
  17. tb33anda3rd
    tb33anda3rd
    also look into any splash apron that can be adapted. this chevy one has really cool lines DSCF0001.JPG
  18. themoose
    themoose
    @hfh
    A bit of taper at the front and some louvers to pull it together a bit...
    hfh, brEad, mike bowling and 4 others like this.
  19. 1-SHOT
    1-SHOT
    from Denton
    Moose has got the look
    themoose likes this.
  20. safetythird
    safetythird
    Love the new lines.
  21. 1-SHOT
    1-SHOT
    from Denton
    I think you might try a V in the spreader bar just my 2cnts. worth
    Cosmo49, brEad, mkebaird and 2 others like this.
  22. 30tudor
    30tudor
    *****in look.
  23. themoose
    themoose
    Lets take a look at that idea... I hope that @hfh doesn't mine me playing around on his thread. It's a great looking car and I couldn't help myself.:D
    kidcampbell71, hfh, Dino 64 and 3 others like this.
  24. LM14
    LM14
    from Iowa
    That looks good as a stand alone part, but I don't think it really compliments the rest of the car. I think the car would benefit more from a modified deuce or model A filler panel. You have some great angles to work with (angle back of the shell, angles from the lower leading edge back and up). To me the flat panel just hides the frame rails and does nothing to accentuate those great angles you have going.
    JMO,
    SPark
    Cosmo49, greaser and Hnstray like this.
  25. themoose
    themoose
    Here's one that's a little more "Real World"
    hfh, kidcampbell71, Corsa and 5 others like this.
  26. 1-SHOT
    1-SHOT
    from Denton
    IMG_7513.JPG Moose I like that look Frank
  27. hfh
    hfh
    from Western MA
    Thank you Moose and all the others for your most helpful comments and suggestions. I need to get back out to my shop and get to work now. HFH.
    Stogy likes this.
  28. alanp561
    alanp561
    What happens if you make your filler piece roll under inside the frame just in line with the bottom of the radiator and leave the spreader bar exposed? I don't have the technical skills to show you what I mean on the computer but I think there should be a gap between the spreader and the radiator.
    Stan Back likes this.
  29. 1-SHOT
    1-SHOT
    from Denton
    I really like the look of the Riley Grill on the 29. The V windshield and Riley grill works off the coach line on the 29 cowl . It also takes away from the look of a cookie cutter cars.
    The original reason people put 32 grills on there hot rod is because it had the radiator in it that supported the V8s remember these were built on a really tight budget. Then everyone wanted that look so people would think their car had a V8 in it wether it did or not.
  30. Stogy
    Stogy
    I really think this Hotrod has a more elegant side and may look better with louvered hood sides perhaps 3 or three strategically placed rows maybe with side exhaust exiting cutout areas on the side panels or down and under...even though I really like to see engine...Good job @themoose
    It needed some digital love...;)
    I'm going to even go out on a sacrificial Limb and say this Hotrod may be well suited to a nice set of polished E & J's. And guess what Hamber @edwardlloyd is on the downslope of recreating primo copies of these...Just a thought...
    pitman likes this.
