Getting tunes to the shop via Wifi
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Dec 20, 2012.
  1. Roothawg
    Roothawg
    OK, I hate to ask this on the main board, but I am kinda at a loss here.
    Here's the situation.
    I have high speed cable internet in my house and a wireless router. The house is approx 100 ft away and the shop is an all steel structure and straight line of sight from the router, just a window in between.
    I have an old Iphone in a dock that I use for Pandora etc for my tunes in the shop.
    Here's my problem: This is great in the summer, while the doors are up, but when it gets cold and I don't wanna open up shop, I get no signal.
    I need a way to mount an external, weather resistant antenna on the top of the shop to get a better signal. What is the best way to do this? Is it even possible?
    I was looking at something like this.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16833164156
    Thanks
    Root
  2. RatPin
    RatPin
    I have the exact situation and my 2G data plan is getting all used up over 3G @ only 10 hours per week.
  3. hd4unm
    hd4unm
    Try changing the channel your router broadcasts with. Channel 6 is default for many, channel 11 has a stronger signal. This might just do it.
  4. greaseyknight
    greaseyknight
    from Burley WA
    Get a better antenna for you existing wireless router, or get a router set up as a "repeater" to put in your shop to boost the signal for the Idevice.
  5. Roothawg
    Roothawg
    Keep in mind, I don't have a computer in the shop. Just a cheap radio dock with an old 3g phone.
    I'll look at the router channel. Will that jack up all my presets for my other devices?
    I can't relocate the router, really. It's where my modem is. I only have internet cable in one room and this location is the closest to the shop.
    I bought one of those repeaters that just plug into an electrical outlet and put it upstairs in the shop. Didn't really make a difference, so I took it back.
  6. hd4unm
    hd4unm
    No, it shouldn't. Your username and p***words won't change.
  7. zman
    zman
    from Garner, NC
  8. Roothawg
    Roothawg
    Motorola Surfboard, Wireless N, DOCSIS 3.0 Cable
    802.11 a/b/g/n
  9. haroldd1963
    haroldd1963
    from Peru, IL
    Have you tried a pair of Rabbit ears? :)
  10. hd4unm
    hd4unm
    You might have to reconnect is all.
    Quick and free.
  11. Roothawg
    Roothawg
    That's about my technical limit.....I haven't tried them with tin foil though.
    I'm just trying to remember the process I went through of setting up the router in the first place.....
  12. GREASER815
    GREASER815
    Just when I was sitting here trying to come up with something smart***, I see one of my locals already has beat me to it. Great Job!
  13. zman
    zman
    from Garner, NC
    I don't think the Motorola like that has a provision for an external antenna. Is there an actual model number for it? Or do you see a port to plug an external antenna into?
  14. Roothawg
    Roothawg
  15. zep058
    zep058
    Were you using the tinfoil this way?
  16. crminal
    crminal
    Traditional would probably a record player.
  17. Ken Carvalho
    Ken Carvalho
    I realize this isn't want your asking for but, I went thru the exact SAME THING!!! I ended up just buying a cheap $100.00 used computer and ran a "CAT 5" cable out to it. Ended ALL my problems and also get the HAMB in the shop too. Just a thought. Rabbit ears are my expertise, so I had my son hook it all up, I just bought the stuff.
  18. propwash
    propwash
    from Las Vegas
    put an ad on C/List or local paper indicating you'd be happy to let a garage band practice in your shop. Make sure they play the music you like.
  19. Wireless routers still have a jack to hook up a wired device... 100' of cat five seems do-able .... plus hanging it 6 feet off the ground would give the wife a solar dryer ... win/win.
    EDIT: CopperImpala .... great minds ...!
  20. GREASER815
    GREASER815
    Dont laugh, that is what I listen to in the garage. Sometimes that is.
  21. cmyhtrod
    cmyhtrod
    from ct
    IF your going to put a pc in your shop, you might as well get XM/Sirius radio and listen to Little Steven....
  22. Roothawg
    Roothawg
    Oh well, thanks for the info. I'll figure it out. I can feel the trad police firing up their engines.......
  23. tnich123
    tnich123
    Just call the guy... you know like they suggested on two and half men.
  24. 47chevycoupe
    47chevycoupe
    from Finland
    I would help if I could but I can not figure out how to use my phone :(
  25. roddinron
    roddinron
    I think you could solve your problem with a range extender available at Walmart, Bestbuy etc. for about $80. You simply put it at the edge of your current range and it, well, like the name says, extends it. So if you placed it on the wall outside your shop, or maybe just outside the house, it should extend it enough to work in your shop. You'll have to find a way to keep it dry though.
    I recommended this to my daughter who was renting and sharing wifi with her neighbor. Then she moved to the house next door and could only connect in the yard. I got her a netgear range extender and she put it in her kitchen window and could connect anywhere in the house.
    I was having the same problem with my cordless phone. I put one in my garage but it would only connect to the base when the garage door was open. I couldn't buy another phone because then it wouldn't work with the intercom on this system. I searched for something like a range extender for it but there wasn't one. Then I moved the base to my bedroom close to the window, and it works fine now.
  26. 37slantback
    37slantback
    As just as a side note, I bought an internet radio from amazon. It has a retro look and it connects to the wifi from the house and it has a menu that lets you select genre of music and then 100's of stations to choose from. I have some oldies programmed in and use it all the time. It still needs a good connection but mine has no problems connecting to the house about 50 feet away.
  27. Ken Carvalho
    Ken Carvalho
    I also think the fact that your shop is sided with STEEL may be causing some of your issue?? Since it works in the summer with the doors OPEN the signal is getting to the device with no problems! That's the issue/ problem I was having also. If the steel siding is causing the "blockage" just adding an range extender/ or booster may not eliminate the problem??
  28. Roothawg
    Roothawg
    Yeah, I know. I was hoping to mount an external antenna outside and run the cable inside. I may have to rethink this.
  29. roddinron
    roddinron
    Walmart has a great return policy;).
  30. hd4unm
    hd4unm
    Here, this link has some good info. I still think you might get the job done without spending a nickle.
    Just Google; how to boost a router - you'll find lots of info, including about everything that has been mentioned.
    Since you already/did have a smart phone... you should we able to find a free WiFi ****ysis app. It will show you signal strength, so you can test and not guess how much you are getting out there in the shop.
    http://www.wikihow.com/Boost-a-Router-Signal
