Gibbs Brand
Discussion in 'The Hokey Ass Message Board' started by Jdee, Jan 14, 2005.
  1. Jdee
    Jdee
    Started working again on my Buick, Had some trouble with the doors not opening and figured I had a lot of alining they were really stuck but I could not find where they were rubbing?
    Used some 3M blocking powder still no luck...
    Got some Gibbs brand in a few days ago from http://roadsters.com/ and sprayed all my door hardware and thought at least until i get to them again they won't rust.
    Well I was working tonight on the nose and decided check on some interior stuff and the dam doors opened like new? I can't belive this stuff! Made my night...
    Just dry *** door hardware i guess, but it must have dissolved some old rust/dust
    not sure. Since I got a lot of painting to do I did a test.
    I tested a bare steel plate by spraying some gibbs on it and the wiping it clean.
    Then I sprayed a coat of Dupont Chromabase over it "no primer" expecting Fisheyes, Not even one, Heated it 400 degrees no problem. Strange stuff just had to test it a little, don't want no funny stuff in the paint shop..
    So far this is neat stuff,
    Jdee
    PS: I'm not saying use this as a base for painting [​IMG]
  2. QQMOON
    QQMOON
    I would like some for my Halibrands.......Is it sold down here?????
    JR
  3. The stuff rules. I use it on all sorts of stuff. Coolest thing is that it can be painted over (when degreased) unlike WD-40. Run your shiznit in bare metal until you see fit, then paint it w/ no worries.
  4. fab32
    fab32
    Just click on the sourse listed above. Dave Mann, the owner of Roadsters.com has it for sale, and I believe he'll ship it right to your door.
    Frank
  5. QQMOON
    QQMOON
  6. Where ya been Jdee?
    Buicks lookin good...
  7. jambottle
    jambottle
    i bought some with the intension of running my 35 pickup in bare metal but when we coated a piece of body metal and left it outside it showed rust the same as the wd 40 test piece.i guess our acid rain is just to potent for any clear coating other than paint.
  8. Jdee
    Jdee
    I'm using it on the insides of my window frames and things that are hard to get paint on ,, It will run down into spots I can't get to , it so thin like water. Not sure but if you are using bondo it might get under it too, so do tests. So far all i see it do is seal stuff. I tested on some old bondo, only a few days though, and the bondo did not delam..
    Jdee
  9. Jdee
    Jdee
    choprods, Been playing with paint [​IMG]
    choprods when you get the time to try some woodgraining,
    let me know, I'll send you some goodies [​IMG]
    Jdee
    PS: thanks for the Chop layout on the Buick could not have done it with out ya!
  10. Jdee
    Jdee
    jambottle, this is more of an in shop product to keep bare metal from rusting not a final coat. WD will ruin a paint job , The Gibbs is just a super shop lube and it protects bare steel nice. Plus other things. Weld through primer Not sure yet. Its working for what I need.
    Plus it will knock Wasps out of the air LOL...
    Jdee
  11. Jdee
    Jdee
    Oh It won't get you 30 MPG. You will have to get a VW for that kind of thing [​IMG] [​IMG] [​IMG]
  12. Yep. I started buying it from a whole other industry years ago. Awesome stuff. Protects bare steel out in the rainy/humid weather and is the best penetrant I've ever used, better than CRC & such and light years ahead of WD40. I had it penetrate to the bottom of a 9" solid rusted bolt through a steel block from putting it on the head only. Also the trigger is so super controllable you can squeeze out just drop at a time without it squirting all over everything, this makes it really last since you don't have to drown things in it.
    Brian
  13. Jdee
    Jdee
    Yeah but you can kill bees with it! when you press all the way down!
    [​IMG] Jdee [​IMG]
  14. BELLM
    BELLM
    jdee thats a kick *** looking car. Buy you a water pistol or supersoaker keep it filled with dishwashing liquid diluted with water for the bees, wasp etc. Dead on killer stuff, much cheaper than Gibbs Brand (save the good stuff!). I have a supersoaker can kill whole nests of wasps & yellow jackets etc 15' up in rafters in my tractor shed, gable ends of my house, etc.. Next to hot rods, my new favorite hobby.
