Technical Gizmo ID please.
Discussion in 'The Hokey Ass Message Board' started by 34 GAZ, Sep 8, 2019.
  1. Anyone know what this is ? All steel, no plastic. Br*** gear drive like a speedo that drives a short axle on each side. Two aluminium lube points for the axle. No markings at all. Hope it,s not from a washing machine :rolleyes:.
  2. Fortunateson
    Fortunateson
    Hmmmm?
    34 GAZ likes this.
  3. 1ton
    1ton
    I'm quessing it's not auto related, but a right angle gear box for a Henway
  4. 31Dodger
    31Dodger
    I'm guessing a generator/water pump attachment for an early 1920s car.
    tb33anda3rd, Hnstray and 34 GAZ like this.
  5. gimpyshotrods
    gimpyshotrods
    The, previously unknown, third Interocitor.
    34 GAZ and traffic61 like this.
  6. traffic61
    traffic61
    from Owasso, OK
    Oscillation overthruster
    34 GAZ likes this.
  7. Its not a Gizmo/……….\
    Its a DoHickeythingmabob
    BigO and 34 GAZ like this.
  8. 6sally6
    6sally6
    I agree, its NOT a Gizmo!.......looks more like a damned "doo-lollie" off of a early Shivel-lay! Probably don't need it to make it run.
    6sally6
  9. That’s a felther****** box
    Desoto291Hemi and 34 GAZ like this.
  10. It’s off a dodge
    It’s the right angle duel pro Pham generator.
    scotty t and 34 GAZ like this.
  11. 302GMC
    302GMC
    from Idaho
    Power sun visor transmission ….
  12. greybeard360
    greybeard360
    Turbo encabulator.
    Hnstray, VANDENPLAS and 34 GAZ like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Posi unit for a skateboard :). Any markings?
  14. DDDenny
    I got nothing.............but then again, it may be a "*****er:eek:mabob", wait, that's a whole nuther subject.
    34 GAZ and 31Vicky with a hemi like this.
  15. 56don
    56don
    I am certain that I do not know what it is, and I am unanimous in that.
  16. loudbang
    The splines on the sliver post look like windshield wiper arm splines.
    34 GAZ likes this.
  17. captainjunk#2
    captainjunk#2
    im guessing a small industrial or agricultural conveyor drive A motor with a worm gear bolts to the open front then a sprocket or pulley bolts to each side shaft
    1953naegle, Terrible80 and 34 GAZ like this.
  18. eaglebeak
    eaglebeak
    Are the two silver things filled with grease?
    If so, they get turned in once in a while to lube the shafts.
    1953naegle and 34 GAZ like this.
  19. It'd make a good quick change for one of those mini vehicles old guys ride around on at swap meets. :p
    'Bout time someone built one that has a motor out front with a shaft running all the way to the back. :rolleyes:
    34 GAZ likes this.
  20. Probably something similar as quoted here. Think i,ll throw it on PWC and see what happens.
  21. gatz
    gatz
    Guessing same, but more along the line of a "universal worm drive" for small industrial use.
    Something that Dalton Gear might have made years ago.
    Typically, only one side shaft needed to be used for mounting a sprocket; depending on direction.
    The grease cups would indicate it was manufactured prior to self lubricating Oilite type bushings.
    @34 GAZ, what is PWC ?
    34 GAZ likes this.
  22. Boneyard51
    Boneyard51
    Iton ...........what’s a Henway????
    Bones
    34 GAZ likes this.
  23. PWC is www.prewarcar.com Euro site where all the br***-era car guys snoop around for a bargain :rolleyes:. Lots of those cars for sale there.
  24. southerncad
    southerncad
    Did some research, and am pretty sure it's a P.T.O. from a Flux Capacitor:rolleyes:
    34 GAZ likes this.
  25. Ebbsspeed
    Ebbsspeed
    34 GAZ and KoolKat-57 like this.
  26. 1ton
    1ton
    Should I tell him? Naw, I want someone else to tell him.
  27. Boneyard51
    Boneyard51
    That used to be one of my Dads favorite jokes. I tried to use it here a few times...... just sits there. Kinda like yours did........ so I thought I would help the joke out. I guess it’s just too old........or we are! Lol
    Bones
    Thor1 likes this.
  28. fordflambe
    fordflambe
  29. DDDenny
    Didn't Norm Grabowski have a Henway?
  30. DDDenny
    Cripes
    fordflambe scooped it!
