GizzleHopper Report
Discussion in 'The Hokey Ass Message Board' started by Beep, Jan 26, 2012.
  1. A close call on the GH.
    I had been thinking for months that I should pull the GH's engine down for looksee. She has been running now for 3/1/2 years with zero issues. Still had good oil pressure etc, but compression was down a littl on some holes. I finally got the energy to pull it down
    Damn glad I did too.
    Two cylinders were badly scratched. Not deep, but definetly not good. 4 rods bearing were showning extensive stress (wear) and I had one scuffed piston. The crank is good, but slightly blackened on one journal. I caught it just in time. All is repairable rather quickly and inexpensively.
    All the top rings were begining to crumble at the edges. Damn that 95% nitro is hard on stuff ain't it.
    She is going back together with a new set of total seal gapless steel rings, bearings and a new valve job. We will be at the Dallas Autorama in February for sure
  2. Ole don
    Ole don
    Sounds like a just in time tear down. No parts donated to the God of Speed, I hope your luck continues.
  3. vrod64
    vrod64
    from Katy,Texas
    Just 3 1/2 years on Nitro ? Seen it run a many of times in Houston and Austin. Amazes me to how they can survive a single cackle run much less the drags.
    Glad it worked out. 3 years ago you were running in Houston and at shutdown, the left breather had fire coming out of it. I am like....That is fuel retension !
    See ya in Sealy in March.
  4. snaptwo
    snaptwo
    Beep , Keep the 'Hopper in fresh parts , you just have to keep those hemi cacklefest guys scratching their heads . HAMBers , if you haven't had the pleasure of hearing that MEL on a big load of "pop" you are missing a sweet sound. Thanks for the updates pal. Spence,aka snaptwo
  5. Are you going to make the march Meet?
    I always enjoy seeing your car. This time bring some XL t-shirts!
  6. wbrw32
    wbrw32
    Brian,Glad you caught it in time.....and no REAL harm done...
  7. 42hotrod
    42hotrod
    from S.E. Idaho
    This is strictly a cacklefest car right? Does it ever make p***es or do burnouts?
    3 1/2 years on 95% is absolutely F'n amazing, must have been built right in the first place!
    Scot
  8. jerry
    jerry
    Nice that you caught it in time! Looking forward to seeing you guys at the LSRU!
    jerry
  9. FrozenMerc
    FrozenMerc
    Glad you caught the problems before you had to pick pieces up off the track. I know alot of us would love to see pics of the motor tore down if you get a chance to snap and post a few.
