Glass cutting with the Flow water-jet
Discussion in 'The Hokey Ass Message Board' started by oaklandhotrods, Feb 22, 2007.
  1. oaklandhotrods
    oaklandhotrods
    Flow International has the new 5-axis water jet machine which has the capacity to cut three demensional objects. Now I know that you can cut flat gl*** with the standard waterjet however does anyone think it's feasable to cut a contoured peice of gl*** like a windsheild with the new 5-axis machine? I'am going to call the guys at Flow on friday and discuss this possibility if they've tried it yet or even thought about it. If they're up to it I'm was going to to also see about having them cut a windsheild for a project I have now. The problem is that most of the new 5-axis machines are owned by the military so searching out an idependant shop who has one would be a difficult task let alone a cheap one, it would be far cheaper to have Flow cut it I think.
  2. studhud
    studhud
    Why not just cut it with a hand held tile saw as everyone else does? LTR Dave
  3. oaklandhotrods
    oaklandhotrods
    Have you actually ever tried to cut curved gl*** with a hand held tile saw? It doesn't work very well... There is something about covering everthing in and or around the shop with gl*** particles that isn't very appealing to me. Besides I actually want it to look professional and I also don't want to go through more than one windsheild because they're not cheap.
    Besides I'm not one to conform to what everyone else is doing, can't someone be different or do we all have to do it like everyone else?
  4. chopolds
    chopolds
    from howell, nj
    #1. if you're too cheap to plan on buying more than one windshield to do a chop, then you're too cheap to have something done on a 5 axis.
    #2. Curved gl*** always has a chance of breaking, if you can't afford it, don't do it.
    #3. There's more to cutting curved gl*** than just cutting gl***. Regular methods usually don't work well. Why? Cause it ain't FLAT!
    There are stresses in the gl*** that get relieved when you cut it. The gl*** sometimes wants to spring and take a slighly different shape. When you 'blast gl***, you can see it. If you are doing it right, the gl*** actually "unloads" and breaks while you are cutting it. Fortunately, you are wearing out a groove in it, that the crack naturally follows, instead of going anywhere it wants (throught the middle of the windshield!)
    #4. Sometimes there's a reason "everyone is doing it". Maybe it works!
  5. old beet
    old beet
    I have had gl*** cut with a water jet, was some years ago. It works well on flat gl***, leaves a nice polished edge. But flat gl*** is supported well while being cut. Don't know about a curved W/S. Also curved laminated gl*** has other problems, as the two pieces kinda fight each other. Two pieces laminated togerher, inside a little big, outside a little small. I think with good support it would work. Don' know about cost?...My 2 cents.........OLDBEET
  6. zippeay
    zippeay
    from Hooper, Ut
    Old beat, "Sorry to hijack Oakland" my Dad and I were talking last night about chopping a top. Neither of us has done one and we both know we can do the chop but the gl*** like most other people is the only problem we can think of we may have a problem with. My question is if you had a frame the exact contour and everything you would need for a windshield. Can you take a piece of laminated gl*** and use a torch to bend the gl*** would that work? Was just a thought, we weren't really sure how gl*** guys do it and that's the only thing we could come up with.
  7. Dakota
    Dakota
    from Beulah, ND
    ORange COunty Choppers Has one.
  8. Goztrider
    Goztrider
    from Tulsa, OK
    Like Dakota said, I was going to suggest OCC from New York. However, if you talked with the guys at Flow, I'll bet they'd be able to suggest someone relatively close to where you are in an interest to promote their product/machine, but to also make it easier for you to find and refer others. Word of mouth is the best advertiser.
  9. old beet
    old beet
    No, torch won't work. You need to cut down a regular W/S...........OLDBEET
  10. Squablow
    Squablow
    There is no way you're going to cut a curved windshield with a water jet. At FVTC where I went to school, we had one and I can't imagine how that would work. First off, it would take an amazing amount of programming to get the machine to follow the cut lines on the windshield. And second, the windshield would have to have a specially built buck or stand to keep it fully supported during cutting. That water/emery mixture is coming out at mach 2.
    Maybe it's possible, but I doubt you'd get it on the first try, and they'd probably be charging 5 grand a cut to do the work.
  11. oaklandhotrods
    oaklandhotrods
    It's not that I'm cheap... it's the fact that I'm using o/e non-laminated gl*** and I don't want to buy the new replacement gl*** because it is infact laminated. To find the o/e gl*** is getting extremely tough and exspensive for an un-cracked, non-chipped, non-fogged, clean peice of gl***. I've had too many gl*** shops break my windsheilds trying to cut them down for me and I'm not about to just throw away $800 on this project, that's right $800 for a windsheild but that's not a new one and I don't want to the new one.
    Squablow- I'm talking about a 5-axis machine, it's the new waterjet from flow that cuts on a 3-demensional scale instead of the original 2-d version you had used. It would be more like a couple hundered bucks not 5 grand to have them cut something, if they charged 5 grand to cut something then they'd be out of business in a hurry.
    Ghoztrider- Yea I had considered OCC and that's what flow had said too, my dad talked to someone out there who runs that new 5-axis and said it's deffinately possible. However he suggested bringing out the gl*** personally and being there to ***ist with the gl***, he said the mail is rather bumpy these days to ship out something like that.
    Thing thing about the water-jet is that it hardly puts stress if any into and on the material your cutting with it. You can lay fruits and veggies on the grid and cut them without even moving your material also with out exploding or breaking them. Something has to be said for that, it's an extremely gently way to cut something. I understand fully that there is load in the gl*** from being formed however if you were to create a wooden buck or similar you could byp*** the excess material becoming unsprung as it's discarded and preventing the gl*** from cracking. I don't see any problem with taking 2-3 inches off a w/s that's 12-15 inches high, remember this isn't laminated gl*** that's why I want it waterjet cut. The waterjet can and will cut up to 400-600 ft per minute on the 5-axis machine so it would take less than thirty seconds for it to make it's cut across the gl*** supposedly.
  12. chaddilac
    chaddilac
    wouldn't non-laminated gl*** just shatter??
  13. -Brent-
    -Brent-
    Maybe you should talk to someone who owns one rather than hypothesize here? Then come back and show us some cool pics and some tech that went into the project.
  14. old beet
    old beet
    What kind of gl*** is non laminated???? Tempered...it don't cut. Tell us what you know and what kind of car? Please!!!!.........OLDBEET
  15. oaklandhotrods
    oaklandhotrods
    When I'm talking about how gentle this machine cuts I'm not hypothesizing anything, I called Flow this morning cause I was being harr***ed by my father about this project. They said it's doable I just need to figure out how I'm going to go about it and when I'm going to make the time to take a road trip.
  16. oaklandhotrods
    oaklandhotrods
    Exactly why I'm looking into the waterjet alternative, when I heard that they're cutting 2 inch thick gl*** with this machine and 8in stainless steel then I had to investigate. The possibilities are endless with this machine, they're even cutting circuit boards with it. The car isn't a car, it's a one of a kind caddilliac.:)
  17. old beet
    old beet
    Come clean, tell us what yer trying to do. Get your facts straight. Sounds like yer makin a mountain out of a mole hill!.............OLDBEET
  18. Squablow
    Squablow
    A couple hundred bucks? I doubt it. The amount of programming time it's going to take to make that cut where you want it is going to cost some money. The actual cutting might be cheap but the time it's going to take to set up the programming and to make some kind of support buck is not going to be cheap.
    And what kind of curved windshield isn't laminated? What kind of a car are you working on?
  19. Ryan
    Ryan
    ADMINISTRATOR
    I talked to a rep at Flow a couple of weeks ago and this very topic came up... He told me that they hadn't tried it yet, but that they were pretty confident they could do it.
    I'd be really interested to see how this turns out... Let me kow if you make it out there.
  20. Rocket Scientist Chris
    Years ago (early 90's), I talked to Ingersol when they were developing their version of the Flow Jet. They had a cutting jet set up in what looked like a bandsaw. The work table could be sized as small as the jet receptical. Anyway, material was basically cut freeform with the jet being stationary. The guys at Ingersol said they could cut laminated safety gl*** but not tempered. When tried, tempered gl*** would shatter. :(
  21. cool57
    cool57
  22. old beet
    old beet
    I think this was for pattern cutting regular gl*** before the curving and tempering was done.................OLDBEET
  23. oaklandhotrods
    oaklandhotrods
    Making a wood buck would be no problem, I can make that here on the cnc router and the programing time and cost wouldn't cost me a dime cause I use the same solidworks 07 that they use so I can just create the program myself to run the curve, the only time consuming aspect of it would be zeroing the head for a start point. The gl*** is hand blown and finding another one has been next to impossible, they can make a laminate but I don't want that.
    Ryan- Yea they were talking about trying it and they seemed eager to make the attempt when I told them what I had here, but yes they were deffinately confident they could do it considering they had succesfuly cut thin porcelin supposedly and silicon based sheets which are fairly fragile.
  24. I'm interested too. I cut windshields on a weekly basis. a way to cut tempered would be very interesting. I have a local waterjet shop and some tempered gl***. I'll let you know how it came out....Jim
  25. old beet
    old beet
    Jim, I tryed to have it cut,tempered, at Hydro Sabre Tech, after an inch or so it broke. Made a mess of his machine. they were not happy!......OLDBEET
  26. chopolds
    chopolds
    from howell, nj
    You can't cut tempered gl***, doesn't matter how you try to do it. It's MADE to shatter if the gl*** is disturbed.
    I think it was Dave SImard at East Coast Custom who was successful at have the gl*** 'un-tempered' at a manufacturer, cutting it, then re-tempering it. He was doing alot of late model Chevy pickups at the time, so it was worth it (large batches of gl***). You need to know the original tempering temperature to do it right, and it's different for differene brands, and batches of gl***.
    FWIW, I think this kid's dreaming, or doesn't know what's going on.
  27. old beet
    old beet
    "The car isn't a car, its a one of a kind Caddilliac" LOL..........OLDBEET
  28. studhud
    studhud
    Yep done it then belt sanded the edges looked totally awsome. To keep the gl*** particles down I used a hose with some water. LTR Dave
  29. studhud
    studhud
    Well I just read the above post and In my experience cutting old gl*** tends to break. If that has even one tiny chip or pit near where you cut it I bet it will break wether you do it with a grinder or the water jet. I believe thats just a characteristic of gl***.A friend of mine worked a a water jet place in richmond cal. They cut gl*** all the time but after a while refused to do old gl*** as it BREAKS. Second question why would you not want to run laminated gl***? Non laminated gl*** is extreamly dangerous. I dont want to see something hit your gl*** while your driving it or the body and frame flexover some big *** pothole you couldnt miss and that gl*** end up it your lap and face. It will be a ****** mess as Im sure you know what your intending to with an unlaminated shield is way dangerous. Dont do it! Lots of people do scary *** **** on here this sound like one of them. LTR Dave
  30. IF you're planning on using tempered gl*** for a windshield, I'd reconsider that plan if the car is going to see any road use. If it's strictly a show car, then that's a different story. If you're planning on using NON -laminated gl*** for a windshield, I'd STRONGLY reconsider that.
    Tempered gl*** is not used in windshield as it is prone to shatter upon impact. Windshields are laminated to keep the gl*** stuck to the laminating layer in the event of impact. If you're clipping along and a rock hits your tempered windshield you'll end up with a lap full of gl*** chunks, at the very least.
