Technical Glass experts please chime in
Discussion in 'The Hokey Ass Message Board' started by 57chevymadman, Apr 30, 2024.
  1. I bought a full gl*** set for my 57 chevy, the windshield is the last to be installed, I inspected the windshield when it arrived a few years back , but not closely enough,
    20240429_211313.jpg 20240429_211306.jpg there is some kind of epoxy still on it, can a gl*** shop remove this and polish it out?
  2. '29 Gizmo
    '29 Gizmo
    from UK
    Looks like its delaminating. May have happened in storage
    SS327 and squirrel like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I agree, unfortunately it cannot be repaired.
    Do you still have the receipt from the company you purchased it from? give them a call and send them some photos, That should never happen to new gl***. HRP
    SS327 and 427 sleeper like this.
  4. I have the receipt, but I would like to install it today, it is definately a resin or epoxy on the inside and outside very thin about .020, super hard material.
  5. alchemy
    alchemy
    I’m no expert, but what would it hurt to try and chip it off? Try a razor blade.
  6. Worth a try with a razor blade, still might need to be polished?
  7. JohnLewis
    JohnLewis
    I'd use a razor then #0000 grade steel wool, shouldn't have to polish.
    SS327 likes this.
  8. Thanks everyone!!
  9. Bandit Billy
    Bandit Billy
    You can't "feel" delaminated gl***. It is on the inside, between the layers. If you feel it, it is on the outside. Like they said above, razor blade and you may try softening it with some paint reducer.
  10. harpo1313
    harpo1313
    from wareham,ma
    Or warm it a bit with a heat gun, A small bit.
    Bandit Billy likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I would not heat it, I once cracked a windshield by d****** a trouble light over the rear view mirror so my striper could see.... simply s****e it off with a razor blade, gl*** is smooth there is nothing for glue to bite into, It should come right off
  12. ClayMart
    ClayMart
    If you can mostly s****e the gl*** clean but still feel the need for some polishing, this video looks like a pretty good tutorial. If you've not done this before you might want to practice on some of your old gl*** first.
    Maybe @Lloyd's paint & gl*** has some suggestions.
  13. Yeah if you can feel it on the gl***, just spray it with window cleaner and use a new single edge razor blade. If there's residue left you can hand rub it with buffing compound, but it should come off with a blade. A used blade will scratch the hell out of the gl***, and doing it dry will scratch it also
    twenty8, SS327, 427 sleeper and 2 others like this.
  14. Razor blade worked, thanks everyone!! It was some sort of epoxy....
    clem, chevy57dude, loudbang and 3 others like this.
