Technical GLASS, How to make a model a windshield frame
Discussion in 'The Hokey Ass Message Board' started by continentaljohn, Jan 29, 2005.
  1. Plowboy
    Plowboy
    Ha Ha Ha, and when I called you earlier you said you were "working".
    I knew better. Nice tech post, but I'll just call you if I need one! Hee Hee
  2. CAS
    CAS
    Pretty darn ingenious, John.
    Good job explaining the process.
  3. Jaypee
    Jaypee
    from Finland
    Nice work, very nice.
    Jaypee
  4. Adam F
    Adam F
    CJ,
    Excellent post....timely as I need a new frame and certainly don't have the dough for a bought one! I just have one question :
    What happens along the bottom edge of the bottom of the screen? How does the rubber strip attach to the frame?
    Thanks!
    Adam F
  5. continentaljohn
    continentaljohn
    Adam, the pipe has no provisions for the weather stripping on the bottom or sides but with a few simple strips of flat stock you could weld up a groove for it.. I see alot of folks just leave it out... If you would use solid stock you would be able to mill a T-slot into the bottom. Giving you a slot for the rubber strip.. But you would have to use a milling machine for this...
    Thanks continentaljohn
  6. Adam F
    Adam F
    Thanks for answering my question !
