Well, We're getting down to the end of my chop top on my '51 Plymouth as seen here.. http://www.jalopyjournal.com/forum/showthread.php?t=231864&highlight=******knuckles ..with that being said it's time for gl*** to be cut. I will make templates from 1/4" plywood. What are the acceptable tolerances between the gl*** and the pinch weld metal? I believe about a 1/4" but I would like to know from people with expierience. Any help would be greatly appreciated. ******Knuckles
I'm not sure exactly what the clearance was when i did my 53 chevy..but it was a little more than i thought it was going to be. And i think it was a little more than 1/4".. The clearance may be different for different car's as well only due to the thickness of the weatherstripping. I'm not sure if the're would be a general measurement. I made a template out of lexan, and installed it in the rubber that i was using for the real windshield, then installed everything into the car to 'fit' it..as if it was gl*** LOTS of in and out to make it fit right, but it made thing's very easy when i had the gl*** installed.
The way mine have been done (a local guy does them) I make my template by tracing the pinch weld then he takes them, takes 1/4" off those lines (makes the window 1/4" smaller where it touches the pinch weld) and then installs it. Little grinding for it to **** up in the center....49-51 Mercs and Fords, but should be the basic idea. Hope this helps.
First, take a look at the type of window gasket you are using! The "old style" ones, like the originals, mount the gl*** slightly in front of the pinchweld. So the gl*** is about the same size as the opening of the pinchweld. A lot of the newer gaskets, or "universal" gaskets are different...some you can tell by the fact that they have a lock-strip that you install last to tighten up the gasket. These gaskets mount the gl*** directly inside the pinchweld. Here you need to have a gl*** that is slightly smaller than the opening. My gl*** guy tapes 2 regular pencils together, and runs them along the pinchweld onto your pattern (keeping one pencil on the metal, the other away from it), automatically putting in the correct gap.
