1952-59 Ford Glove box door question
Discussion in 'Off Topic Hot Rods & Customs' started by Zax, Apr 22, 2021.
  1. Zax
    Zax
    Is there some kind of spring to ***ist in opening the glove box door? I have to push the ****on and use a fingernail behind the door to get it to open. Seems like something must be missing or maybe out of adjustment on mine.
  2. Bleach
    Bleach
    I'm ***uming you're asking about the one in your Ford truck? It should just pop open from the ****on latching mechanism and it's own weight. The ****on latch and the hinges may need a good lubing.
  3. Zax
    Zax
    Apologies, vehicle in question is a 53 Customline
    My old f100 didn't have a glovebox latch at all, just a pull knob
  4. Dos Cincos
    Dos Cincos
    Might need adjustment. On my 55 you just push the ****on and gravity handles the rest.
  5. Bleach
    Bleach
    Same on my '56. Again the ****on and hinges might need a little lube.
    I forgot my '63 F100 was like yours.
  6. Paul2748
    Paul2748
    Same on my 54 - no spring. Occasionally I have to do the same thing
  7. !!!RIOT!!!
    !!!RIOT!!!
    from Austin, TX
    danman55 likes this.
  8. jimmy six
    jimmy six
    My 56 has 2 pointed rubber stops that compress slightly and ***ist in opening when I push the ****on.
  9. Zax
    Zax
    Thanks, you solved the mystery. I can clearly see where that tab used to be on my '53. Looks like it snapped off sometime in the last 68 years.
    qicvick and !!!RIOT!!! like this.
