GM 10 Bolt axle help needed..
Discussion in 'The Hokey Ass Message Board' started by Scott41chev, Sep 24, 2013.
  1. Scott41chev
    Scott41chev
    from England
    I just finished up installing a GM 8.2 10 bolt axle under my 41 chevy stepside and after getting the brakes up and running discovered one of the wheel cylinders is leaking like hell, my issue is that I dont know what car the axle originally came from and so im not quite sure what part to look for other than GM 8.2 10 bolt axle wheel cylinder. Are they all the same for that axle type or specific to a certain drum size?
  2. M224SPEED
    M224SPEED
    from Missouri
    You can get a casting # off of the wheel cylinder,or just take it apart and measure the pistons,most of the rubber cups have the size printed on the inside of the cup.
  3. Scott41chev
    Scott41chev
    from England
    Thanks for the help, do you know if most 10 bolt axles all use the same size cylinders or not?
  4. 1934coupe
    1934coupe
    I believe they do if they are 9-1/2" drums. 11" drums may take a different size. But do as M224speed says it should be no problem.
    Pat
  5. can have either size drums
    check the size cyl for 78 impala should be in book or rock auto
    chromedRAT likes this.
  6. clays diff
    clays diff
    all rear wheel cyl are the asme 8.2 8.5 and even 12 bolt they all use 10 inch brakes except 11 inch on wagons that are impala with 5on5 bolt pattern the backing plates all enterchange also
  7. tfeverfred
    tfeverfred
    Take the old one and match it up. There can't be that many differences, if there are any.
  8. 1971BB427
    1971BB427
    from Oregon
    All the same, regardless of which 10 bolt you have. Better get both sides, as once one starts leaking, the other will follow soon!
  9. Orn
    Orn
    1934coupe is spot on. 9-1/2” and 11” drums have different size wheel cylinder. Guess how I know ;)
  10. gtowagon
    gtowagon
    Basically there are 2 versions for 9 1/2" brakes they are either bolted on or have a retaining clip on the backside
