GM 10 bolt questions
Discussion in 'The Hokey Ass Message Board' started by BinderRod, Jun 25, 2009.
  1. BinderRod
    BinderRod
    Just a few questions.
    What is the fluid capacity for a 10 bolt GM?
    I saw this on one of the hot rod shows on a Sunday morning. Has anyone ever put the rearend grease, posi lube in a zip lock bag and placed it in the housing and bolt up the rearend cover? If it works that would sure make for a clean fill. They said the plastic just melted away and blended into the oil. Plastic is a petrolium base. Lets hear good or bad. Thanks Keith
  2. SakowskiMotors
    SakowskiMotors
    really?
    Sounds like a bad idea. kidding?
  3. Brickster
    Brickster
    5-6 pints. I wouldn't want anything extra in there.
  4. Tony
    Tony
    Whats wrong with pulling the plug and just filling it there? As far as capacity, it normally take a little more than a quart or so. I fill them and use an allen wrench to check the level..Put the short end in the hole and when it's about 1/8" to half way up, your done.
    I personally would not do the bag trick..petroleum based or not..
  5. gtkane
    gtkane
    I would be worried about the bag wrapping around a bearing and starving it of oil. Besides, it ain't that hard to fill a 10 bolt the conventional way.
  6. TrannyMan
    TrannyMan
    I wouldn't do the plastic bag thing either.......
  7. I would not do the bag thing but sounds like a mail-order outfit or a shop that sells completely ***embled rear ends trying to eliminate the possiblility of a customer not putting grease in his newly purchased rear end ***embly. LOL
  8. Noname38
    Noname38
    I wouldn't use the bag trick. Just fill her through the plug
  9. dalesnyder
    dalesnyder
    We have a machine at my work that forms pockets in a plastic film then puts a layer of plastic film over the top and seals it all around.. Sort of like pre packaged lunch meat.You should see what the t*******s can do to the drive shafts and bearings.. No way.
  10. BinderRod
    BinderRod
    Looks like everyone agrees, NO Plastic bag.
    I have just 1 more question. Do you still need the posi addative if your using synthetic gear lube?
  11. Yes on posi lube, as it is a friction modifer for the clutchs, the cone type posi I don't know ?!?!........and I was told by a oil rep that normal oils are microscopicly like gravel and synthetics are like ball bearings in laymens terms.
  12. tommy
    tommy
    Ain't that why they invented the mustard bottle?
  13. yellow wagon
    yellow wagon
    from WI
    grab the gear lube that has the pointed top....just squirt the **** in
  14. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    that sounds like a real good way to **** up a perfectly good rear end.
  15. Hot Rod To Hell
    Hot Rod To Hell
    from Flint MI
    Just a heads up, your posi will WORK BETTER and LAST LONGER without the additive.
    The additive is made to MAKE your posi slip... bad for performance, but the customers don't bring their cars in all the time complaining about chatter around corners.
  16. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    I have heard arguments for and against it...it is also supposed to have a conditioning agent in it that makes the clutches last longer.
    whatever it is, I just want to know why it smells like a salmon fillet left on Your back porch for a couple days.
  17. Shaggy
    Shaggy
    from Sultan, WA
    I'm sure the reason for the bag trick is on a lot of newer 10 bolts there is NO fill hole,
    that being said, I still wouldnt use that on my 81 camino daily
  18. TudorJeff
    TudorJeff
    I saw them do the baggy trick on junk yard wars a few years back but they only needed the rear end to last a very short time.
    And if the capacity question did not get answered, I just did mine and it took 3 of them squirty bottle quarts to fill it perfectly.
  19. Truckedup
    Truckedup
    What kind of 10 bolt rears have no fill hole?
  20. Retro Jim
    Retro Jim
    Do you really believe everything you see on TV ? I wouldn't trust the stupid ideas they come up with sometimes on the Spike channel ! Do it the way everyone has done it for many years , just take the plug out and fill till it comes out then plug the hole back up . Now that wasn't so hard was it ?
  21. OLDSKEWL61
    OLDSKEWL61
    ive used the baggy trick in my 4wd for on the trail fixes but changed it and flushed housing when i got home
  22. roughidle
    roughidle
    from iowa
    No bag, bad idea.
  23. BinderRod
    BinderRod
    The way it is now I am getting a lot of popping and chatter when I go around corners and when I back up. I am popping the cover off this weekend and cleaning the rearend out with brake cleaner and adding synthetic lube along with posi additive. (without the plastic bag)
  24. Shaggy
    Shaggy
    from Sultan, WA
    80's g-bodies i know, may be others
  25. jamesgr81
    jamesgr81
    Not buying no fill hole.
    How do they get gear oil in a c-clip type axle?
    Fill hole is in the front casting on every one I've looked at.
  26. milwscruffy
    milwscruffy
    you must never of had a posi that didn't slip and acted like a spool . not a happy sound or feeling, use the lube.
  27. J&JHotrods
    J&JHotrods
    X2.
    10 bolts take usually 1.8 to 2.3 qts of lube. Fill it until lube starts to trickle out of fill hole. Done. Never heard the bag idea. But....if it was on TV it has to be true, right:rolleyes:?
  28. pinstripebob
    pinstripebob
    from Carmel, IN
    I have an '80s Grand National rear end that took a little less than 2 quarts of oil. It has the fill plug and the stock cover, but I did see that plastic bag thing done on TV once a few years ago. I think it was on Trucks during a budget build as a trail trick.
  29. torchmann
    torchmann
    from Omaha, Ne
    I have the solution for no fill hole...Make one
    I had an 85 chevy with the 14 bolt that did have a fill hole. We tried and tried to get that plug unscrewed but it just stripped out. not even heat or impact would budge it.
    I knew it was low on fluid. I had to run the truck from Omaha to Denver and had to leave the next day...what to do???
    Y'all know those little rubber vacuum line caps in the "HELP" isle of the autoparts store?
    I drilled a fill hole at the oil level line a little smaller than the 1/4" rubber cap.
    I filled the axle with lube.
    I put a small punch into the rubber cap and pushed it round end first halfway into the hole...same way you install rubber mutes on a commercial buildings steel door frame
    It never leaked.
