GM 10 Bolt Rear Question
Discussion in 'The Hokey Ass Message Board' started by rollin63, Jun 11, 2009.
  1. rollin63
    rollin63
    So I picked up a NIB Eaton Posi and Motive Gear 3.73:1 Ge****t from a guy who needed some money for very cheap. They are for GM 10-Bolt and the Posi says it it for 30 spline axles. I figure I can throw a 10 Bolt under my coupe and it will be plenty strong since the car is so light. I have a couple older 8.5" 10 bolt housings and center sections (79 olds and 77 Nova). When I look up the posi unit it says it fits 1988-Up GM Car/Truck. The Eaton part number is 19559-010. So I am wondering if I can make this posi unit work in one of the housings that I already have or if I need to look for a newer unit. What are the differences? Is it just axle spline? I will be buying new axles anyways, so I should be able to order whatever I need. Any advice would be appreciated. Thanks
  2. bshepherd
    bshepherd
    from michigan
    not sure if it will work I know pre 88 10 bolts had a bigger ring gear
  3. v8 Bake
    v8 Bake
    88 and up should be a 7.5 ring gear and older is 8.5 if thats the case it wont work.
  4. Geeto67
    Geeto67
    I think the main difference is the 1988 up axles were 30 spline and the earlier ones were 28 spline (but you can convert to spline). I think the later units also used that awful limited slip unit that always goes bang. Also I think the bearing sizes change internally so you may have to get new bearings as well.
    I think some of the full size truck and 4x4 s-10s still had 8.5 ring gears. none of the p***enger cars though.
  5. Larry T
    Larry T
    Hey guys, you're sitting in front of the greatest research tool since they invented libraries and you can't find out what's what?
    There are 4 different 10 bolt rear ends, but the Eaton unit you have is a 3 series carrier that fits a 8.5 rearend with 30 spline axles. It will fit any 8.5 rearend if you use the right custom axles.
    Larry T
  6. Ebbsspeed
    Ebbsspeed
    Not true. There were a lot of 10-bolt rears pre-88 that were 7.5 and 7.65. In fact, most of them in the 80's were.
  7. Larry T
    Larry T
    I'm pretty sure the early 7.5 gears (Monza) were different than the 82 up Camaro/S-10 gear. And you have 8.2 and 8.5 10 bolts too. Look at a Richmond Gear catalog, it should break them down for you. GM pickups used the 8.5 rearend for quite a while.
    Larry T
