Technical GM 235 to model a rear end
Discussion in 'The Hokey Ass Message Board' started by 1942g506, Jun 12, 2025.
  1. 1942g506
    1942g506
    I’ve got a spare model A frame, a good 235 and a rear model A axle. Was thinking of doing a TROG rail. What’s my options on the 235 to the model A rear or am I better off doing something else? Thanks
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The rules state*
    Transmission: 3 speed Ford ONLY,
    Ford banjo rears ONLY
  3. manyolcars
    manyolcars
    It's almost as if they are saying ' traditional hotrod' only.
  4. 1942g506
    1942g506
    It’s almost if one should read the rail class rules and not the OHV class rules. ;) Acceptable engines are, FLATHEAD 4 cyl, FLATHEAD V8, STRAIGHT SIX and OHV 1949-1954. Last time I checked the GM straight 6 was being made even earlier than the ford flat head.
  5. 1942g506
    1942g506
    For the OHV class not rail/drag.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I sit corrected:)
    So where do you find the set of rules?
    I just asked You know,,Who-ogle:D
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
  8. stuart in mn
    stuart in mn
    https://www.theraceofgentlemen.com/entry Oddly, while the rules specify the trans and rear for early OHV they don't say anything about drag/rail.
    DRAG/RAIL: All Entries must use stock model T or A frames only. Homemade tube needs to be submitted for approval. You can not lengthen frames over the stock FORD MOTOR COMPANY length, you may shorten if you wish. Early homemade tube frames will be accepted. Wheel base or front and rear axels may move or be altered in either direction. Acceptable engines are, FLATHEAD 4 cyl, FLATHEAD V8, STRAIGHT SIX and OHV 1949-1954. No bodies or tin is allowed in the drag class, only a small firewall if desired. Roll bars must resemble safety bars of this era. Square bars, round tube only. No full cages or roll bars made from exhaust tube.
    EARLY OHV: Engines 1954 or older. All makes USA. All cars or trucks will need to be hopped up, cut down or customized in a traditional late 1940s to early 1950s style. Transmissions: 3 speed Ford ONLY, Ford banjo rears ONLY. Bodies up to 1941 (exception for this class only). No modern wide slicks unless pre-approved. More modern years can be submitted for special consideration.
    Tow Truck Tom likes this.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
  10. Budget36
    Budget36
    So back on topic:). Is there a 235 to Ford transmission adapter the OP can use, or can say a GM transmission be adapted to the Model A torque tube?
  11. hotrodjack33
    hotrodjack33
    Hmmm, so let me get this straight...if you had a cut-down 29 Chevy roadster with it's original OHV 6, you would have to convert to a 3 spd Ford transmission and banjo rearend?
  12. Gofannon
    Gofannon
  13. Budget36
    Budget36
    How did they ride when new? I assume you got one right off the lot;)
    How’s it going, Jack?
  14. GuyW
    GuyW
    Model A rear ends are weaker than later bajo rear ends, but on the sand it probably won't matter 'cause you can't hook up anyway.
  15. hotrodjack33
    hotrodjack33
    Hiya Mike.
    Nice to hear from you...all except for that "old man" cheap shot. LOL
    Budget36 likes this.
  16. Budget36
    Budget36
    Love ya Jack!
    hotrodjack33 likes this.
