Technical GM 4-71 blower
Discussion in 'The Hokey Ass Message Board' started by Poppinjohnnies, Aug 10, 2022.
  1. Poppinjohnnies
    Poppinjohnnies
    I got a pair of 4-71 Detroit Diesel blowers. I’m considering keeping one and running it on the 383 in my’59 GMC and selling the other one. Is there still a market for these? Also, any tips or suggestions are most welcome. I’ve never had a blower motor, so I’m a rookie. With an extremely limited budget, I figured I would have to dig up the manifold, blower drive, etc. at swap meets.
    -Brent- likes this.
  2. 19Eddy30
    19Eddy30
    from VA
    Their are many threads about 4-71 & other GMC blower sizes , most are going to point you to search threads unless there's a pacific question that you have.
    mad mikey and Poppinjohnnies like this.
  3. Mike VV
    Mike VV
    from SoCal
    Sell'em both, buy a fresh 6-71...ready to go.
    You'll be much happier, from beginning to the first trip down the street.
    Mike
  4. sine-bar
    sine-bar
    from Iowa
    I would possibly be interested in one if you wanted to sell it. I have a 315 Hemi i want to put in my 41 Plymouth pickup.
  5. 19Eddy30
    19Eddy30
    from VA
    like Mike VV said , even if you do most of work its adds up
    Just average prices
    $3000 -4,500
    The most expense will be intake
    A 4-71 $450-600
    But you could use a 6-71 around same price with 1/4- 1/2 aluminum plate to adapt,
    Or make a plate to bolt to a single four or dual four intake like before production intakes were made
    Poppinjohnnies likes this.
  6. AngleDrive
    AngleDrive
    from Florida
    IronFord, rod1, Desoto291Hemi and 7 others like this.
  7. Poppinjohnnies
    Poppinjohnnies
    mad mikey likes this.
  8. Poppinjohnnies
    Poppinjohnnies
    Whoa! a 4-71 on a 4 barrel intake?!! I've got to see this setup.
  9. Budget36
    Budget36
    I recall a recent post (may have been an old one bumped up?) of a member casting and machining 4-71 intakes. From Australia as I recall.
  10. 19Eddy30
    19Eddy30
    from VA
    In mid 50s HRMagazine,
    If you are new to Hot Rodding ,
    What about direct drive the blower to front of crank , No chain or belt before belts , I think Moon was first company to do so ,
    Lot of thing guys where doing , being creative,
    About two months ago there was a thread started where someone found a article how to get over 400 some cubic inches out of a small block Chevy and I think it was before 1964
  11. 19Eddy30
    19Eddy30
    from VA
    Back then most used Vbelt as power increased more V belts where add because of slippage, some used chain then 1/2 belts by Crager
  12. 19Eddy30
    19Eddy30
    from VA
    Remember Flat Head Ford?
  13. Budget36
    Budget36
    I thought he was making them for a SBC? Oh well, partial memory is still working;)
  14. gimpyshotrods
    gimpyshotrods
    Get a 6-71 manifold, and make a pyramid adapter, to run BOTH 4-71s!
  15. Poppinjohnnies
    Poppinjohnnies
    I like the way you think!
  16. gimpyshotrods
    gimpyshotrods
    The adapter would be made from flat aluminum plate.
    Three flats, and two triangles. Carb adapters would be similar.
    If I had two, and a 383, I would already be welding.
    SS327 likes this.
  17. DDDenny
    Or............
  18. 19Eddy30
    19Eddy30
    from VA
    Not Busting on the OP might be new to this Disease, now we will have to up load a pic, I think Gimpyhotrod is the
    ""Y"" manifold , 2 4-71 @ like a 45 degree angle??!!!
  19. 19Eddy30
    19Eddy30
    from VA
    This is the stuff I like to see & share ,
    Guys that thought outside a of the box & an imagination to go fast!!!
  20. saltflats
    saltflats
    from Missouri
    Wouldn't a 4-71 be to small for a 383?
    SS327 and 427 sleeper like this.
  21. 19Eddy30
    19Eddy30
    from VA
    Probably at its max ,6-8 pounds of boost on a 383 500-550hp under boost maybe 570ish just taking a guess without doing the math
  22. gimpyshotrods
    gimpyshotrods
    Since they are not yet converted, I would keep the the lip on the edge, to help with mounting.
    I am not sure what the angles would be.
    Like this:
    Poppinjohnnies, 19Eddy30 and adam401 like this.
  23. adam401
    adam401
    I'm putting a 471 on a flathead right now but 2?? I like 2 much more betterer haha. Thats rad. I wish I had never seen this and so does my wallet!
  24. Poppinjohnnies
    Poppinjohnnies
  25. gimpyshotrods
    gimpyshotrods
    I would build the adapter so that the 4-71s are pushed forward so that the front surface of the cases are where a 6-71 would be, on that same manifold, so that all 6-71 drive equipment could be used.
    Extra-long snouts are less common, and often cost more.
  26. Bandit Billy
    Bandit Billy
    You’re pouring vodka on your cheerios again Douglas.
  27. 19Eddy30
    19Eddy30
    from VA
    I honestly can't say what the biggest expenses , blowers cases with rotors or the extra parts needed to compleat,
    $1,500-2k
    Mix of new & used
    gimpyshotrods and Poppinjohnnies like this.
  28. A Boner
    A Boner
    Wouldn’t a 4-71 be perfect for a street driven SBC powered hot rod. To me 6-71’s look almost too big on a SBC unless you are a serious racer.
  29. gimpyshotrods
    gimpyshotrods
    Onn a 283, maybe. A 4-71 would need to be overdriven by quite a bit to make decent boost on an 383.
  30. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I have a 3-71 which is one step smaller than the 4-71 u are tinkering with. I built my own manifold using a 2-2 flathead intake as a base. Looks good on paper, but not ever run or tested. 4F7539C0-394B-4682-9625-CFED2127467F.jpeg E1D68A63-21FF-405B-93BE-FAC26AD9407B.jpeg 2B1084C6-40C4-41DD-A599-F12CC3168EBA.jpeg D58307E5-51C3-4793-8DAB-E55579133A04.jpeg
    flyin-t, GordonC, 2Blue2 and 6 others like this.
