GM alternator on a Flattie
Discussion in 'The Hokey Ass Message Board' started by 26 FlatRod, May 25, 2005.
  1. 52Flat
    52Flat
    from Evans, GA
    Well, I finally found a machine shop to fix me up. I got 1/8 inch shaved off the engine side of the bracket. Cost me $10. Fits perfect now, but I think I lost about 1/2 inch of vertical adjustment. That shouldn't matter much.
    M Joiner
  2. ken1939
    ken1939
    I fabed my own bracket using a stock type generator bracket. bought a chrome hold down kit for gm alts, and welded them to the bracket.
  3. AV8Paul
    AV8Paul
    I noticed you have an aluminum pulley on your alternator. It looks like it's starting to wear you belts out. I had an alum pulley on my alt and as it wore out, the belt started to ride deeper in the groove and would fray the belt edges. I went thru two or three belts a year. I finally found a steel pulley and have driven with my current belt, over 20K miles. Check it out.
