GM bellhousing questions
Discussion in 'The Hokey Ass Message Board' started by 73RR, Mar 23, 2010.
  1. 73RR
    73RR
    Quick question for the BOPC guys...will a 79 Poncho bell # 10008977 fit on a 500 Cad?
    Thanks
  2. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    It should. I have never put a manual behind a Caddy engine, but a TH400 from a Caddy will bolt right up to a Pontiac.
    Some of the BOP bells have dual bolt patterns for Muncie/Saginaw/BW trans, and a Ford pattern, as Pontiac used the Deerborn 3 spd as a H/D option on the 350 Firebirds of the early 70's.
  3. bobscogin
    bobscogin
    Agreed. "Modern" Buick, Olds, Pontiac, and Cadillac share the same pattern. Don't know from actual experience, but I've read that the Cadillac crank is not machined for a pilot bushing since they were never offered with a manual trans. Just thought you may want to check that if you haven't.
    Bob
  4. [​IMG]
    double check to see if the bell has dual starter pockets, not sure what side the starter mounts on the caddy. pontiac is on the left side.
    Steve
    Hosting-
    Thur-Sun April 8-11, 2010 12th annual Pontiac Heaven Phoenix www.pontiacheaven.org
    Sunday April 11, 2010 8th annual Nostalgic Show & Go! Phoenix www.nostalgicshowandgo.org
  5. Rich Rogers
    Rich Rogers
    It should bolt up but you better have one hell of a trans to hold it. I was talked out of bolting my 472 to the Muncie M-22 because of the torque of the Caddy compared to a BBC.
  6. Deuces
    Deuces
    Ditto on the pilot bearing for the caddy crank!
  7. 73RR
    73RR
    Thanks Guys, much appreciated!
  8. The Brudwich
    The Brudwich
    It will bolt up, but you can only use the Pontiac bell housing if it has dual starter locations. Only Buick has the same stock starter location as the Cadillac (p***enger side starter).
