Technical Gm bowltie heads
Discussion in 'The Hokey Ass Message Board' started by Oldfart59, Nov 6, 2021.
  1. Oldfart59
    Oldfart59
    Are gm bowltie heads have raised exhaust ports trying to make shure trying to find header that will work
    The problem with the header they don't fit angle plug heads Un less they are raised ports
  2. 1934coupe
    1934coupe
    Oldfart I'm not exactly sure but I don't think so. I had a set on my MG once and the headers fit both the angle plug and straight plug old fuelie heads. And the headers wound up in the same place ch***is wise.
    Pat
    Deuces and loudbang like this.
  3. Oldfart59
    Oldfart59
    Ok that what I thought they were stock locations
    The trouble I'm having can't find header to fit in my Ch***is with angle plug heads
  4. I always thought the angle plugs helped on the header clearance.
    Shouldn’t normal headers fit angle plug heads also ?
    Tommy
    Deuces likes this.
  5. Oldfart59
    Oldfart59
    Not on my Ch***is it in a s10 Ch***is what the headers are designed they hit the tubes
  6. jaw22w
    jaw22w
    from Indiana
    Angle plug heads and header interference has been a problem since angle plug heads were introduced. There are short plugs on the market that I have heard used in this situation. Though I can't help with brands or part numbers.
    Also it has been shown that a well placed dent in the offending tube won't hurt performance.
    427 sleeper and Deuces like this.
  7. Deuces
    Deuces
    Eccel (sp) spark plugs made those short plugs...
    427 sleeper likes this.
  8. Oldfart59
    Oldfart59
    Yes I was told but my headers I have are to small for my motor
    Have a 406 with a .513 roller camshaft and 9.5 compression
    The header I have are 1 1/2 tube and 2 1/2 flange
    They quit making the the header I want they are 1 7/8 and 3 1/2 outlet
    The only thing I fond is fenderwhell hearder
  9. DDDenny
    I don't know all the particulars of your engine but it should be well supported with 1&3/4" headers, which will bolt directly to your heads, as far as I recall most 1&7/8" headers require adapters.
    427 sleeper and Budget36 like this.
  10. Oldfart59
    Oldfart59
    69490 headers should work
